#3631
The TC3 and TC4 use standard hardware. TC5 and newer went to metric. But I think even the TC6 has 1 or 2 parts on it that are still standard.
#3632
#3635
I highly recommend his work
#3637
A Challenger is 200mm in front and 210mm in the rear. With the front tires being 28mm just put them on the car and it should be close. The rear should be fine also because the tires are 31mm with a 6mm offset wheel. If you find you want to space it out more just add some shims inside the wheel and/or go to a bigger wheel hex. The most I've done is go from a 4mm hex to a 6mm hex.
#3640
TommyR if your looking for an excellent TC6 my team mate does not like VTA (to many moving parts). I rebuilt his car with many new parts including all new ball bearings. I might have been raced twice. I don't have pictures but it has a Javelin body I painted. If anyone is interested let me know and I'll send you his e-mail.
#3641
you can shoot a PM to dodgeboy ( http://www.bodiesbybean.com/ )- he's the guy that does all my painting...all his bodies are all paint, very little to no actual decals on the stuff he does
I couldn't agree more. Chris is a top notch painter.
#3643
#3644
