5B needed upgrades
I might get the RB Innovations air filter which forces air into the engine for more power.
http://www.davesmotors.com/s.nl/c.88...t.A/id.8022/.f
Upgrades
Hotrod-
Do not try the SS pipe, its worthless if you've run a Dominator.....No low end at all.
#1 pre-filter for the pull start
#2 Fail-Safe
#3 One of the recommended tuned pipes, I prefer the Dominator v1 or v2
#4 Hostile MX rear tires
#5 HD Beadlock rings
I'm sure there are others that people recommend, but generally, just replace parts as they break with upgraded items
#2 Fail-Safe
The more info you can give us, the better we'll be able to help you. Where will you be using your Baja; dirt, grass, and/or sand? Are you planning to install a high HP engine in the near future? Are you a basher, or a racer?
#1, above all else, you should have a remote kill switch
#2, outerwears prefilters for your air filter, and pullstarter, and crankcase to protect your pullstarter in even the dustiest conditions
#3, upgrade the stock plastic clutch bearing carrier with a metal one, be shure to get an enclosed version if you'll be running in sand
Thats where you go if you wanna deal with retards all day. You need to check out www.bajaaddicts.com or www.rclargescale.com if you want good info without all the BS of a communist forum.
So I just took off the engage RC pipe I have. I tried the ss pipe I have sounds good but a little loud for me. Lost alot of bottom end. May have gained a little top end. So far out if the three the dominator pipe runs best. Good bottom and great top. Just not sure I like the pipe running down the side of my machine.
