C-clip install
Old 01-25-2014 | 05:51 PM
Default C-clip install
I am giving up!!!!!! who can I send a .12 piston&rod to to replace the clip??
I bought a bag of 5 clips and I am down to 1!!!!! now I know why I never fooled with anything smaller than a .21.help please,mike.
Mikiehotrod is offline
Old 01-25-2014 | 07:16 PM
hi one of my mates uses the eye of the needle to change clips we use small /very/ we onley change 1 the end with the hole in wrist pin and I was told if you want you can do it in a glad bag so you can find the clip when it vanishes I have avoided this prob but it gets up my nose to have to get someone else to do it/takes 1 hour round trip to get what takes him 1 minute make sure you get piston on the right way or you will brake it//the voice of a 65year old novice//ha
greg.dawn is offline
Old 01-25-2014 | 07:29 PM
greg,how does he do it with the needle and why the pin end with the hole in it? also I see that part 5200 shows a clip with the little ear and just a plain circle...is there a difference? thanks,mike. PS,if I have someone do it,it will go by mail!
Old 01-25-2014 | 08:46 PM
dan_vector's Avatar
What I do is put one end of the clip into the groove and then use a wine cork over the top and twist it anti-clockwise while applying a bit of downward pressure. That gets it in the hole and then I use a small flat blade screwdriver and gently push the clip to locate it fully.
dan_vector is offline
Old 01-26-2014 | 07:58 AM
hi dan,do you put the ear(tang) side in 1st or the plain side of the clip 1st? thanks.
Old 01-26-2014 | 09:05 AM
the plain side 1st
kyosho malaysia is offline
Old 01-26-2014 | 03:25 PM
I would guess its to fit the eye of the needelhole goes over clip and twist it I tried it on some old pistons first and it was fine my fingers aren't much good so I use pliers
greg
it was great when engens were chep just run till they went bang/ha
Old 01-27-2014 | 12:48 AM
dan_vector's Avatar
Oops double post!
dan_vector's Avatar
Plain side first as the end could scratch the piston as you rotate it into the hole. It isn't easy but after you've done it a few times it just tends to 'click' and you'll be able to get them in straight away!
Old 01-27-2014 | 06:54 AM
Roelof's Avatar
Scratches arround the hole of the piston pin will not harm the performance, not even a tiny bit. I always put one end of the clip in the hole, put my thumb on it and with the tip of a hobby knife I push in the other end of the clip.
Roelof is offline
Old 01-27-2014 | 07:42 AM
thank you to all who have replied,but after the 5th clip took flightit is going to someone who has more patience than I have.
Old 01-27-2014 | 07:49 AM
dan_vector's Avatar
Lol. Good luck. Perhaps go with the engine and watch how he/she does it so you will be ok next time!
Old 01-27-2014 | 08:04 AM
wish I could! I am a over the road trucker and the piston/rod is going by mail to 6hrs from where I live. if time were a little more on my side I would buy another pack of clpis and give it another shot.i am also a nhra drag racer and still have to put my motor back together and get ready for upcoming races,waayyy to many hobbies....but I love All of them!
