Old 01-26-2014, 08:43 PM   #1
xrayracer1's Avatar
Default Can after run oil go off?
Hi guys, i just have a question. Is it possible for after run oil to go "off"? I went to put some after run oil in one of my rc's today and when I put some in I noticed that it had turned a funny brown colour. I don't get to use my nitro rc's very often so the bottle has been standing for a while. (Although it's not very old). It's the ZAP brand after run oil.
xrayracer1 is offline   Reply With Quote
Old 01-26-2014, 10:46 PM   #2
asw7576's Avatar
Oxidation has changed the color of your after run oil.
I wouldn't use it anymore for engine maintenance oils after oxidation had occur.
You could use the oil for lubricating garden locks, door hinges, hole keys.
Old 01-27-2014, 01:45 AM   #3
dan_vector's Avatar
Trader Rating: 27 (100%+)
Yes. Don't use it for engine maintenance anymore. The same can also happen if you leave the bottle in direct sunlight as well. I do have after run oils in my kit which are quite old and are still ok as they've been kept airtight and out of sunlight/frost etc so there isn't really a shelf life per se. Depends how you are storing it!
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-27-2014, 04:04 AM   #4
i use auto transmmission fluid as ARO for the past few year,so far i didn't facing any problem. antioxidant is one of the main additive in ATF.
kyosho malaysia is offline   Reply With Quote
Old 01-27-2014, 04:05 PM   #5
xrayracer1's Avatar
Thanks for the info guys.
Old 01-27-2014, 11:45 PM   #6
i used trans /oil and when we pulled piston out it was all stuck to inside of piston have had no trouble with singer mashine oil //wollies $2.50
GREG
greg.dawn is offline   Reply With Quote
Old 01-28-2014, 05:45 AM   #7
GREG
singer oil similar to one way bearing oil
Old 01-28-2014, 06:49 AM   #8
kylehirano's Avatar
Trader Rating: 14 (100%+)
WD-40 works just as well as the above mentioned and is cheap.
A bad day racing is still better than none at all.
TAMIYA TRF Racing Factory
CWRCB-Central Washington R/C Boat Club, RCUnlimiteds
kylehirano is offline   Reply With Quote
Old 01-28-2014, 08:48 AM   #9
Default After run oil
Been using Marvel Mystery Oil for probably 30 years and the quart I bought back then still is fine. Was told by someone in the outboard industry not to use WD-40 , the contention was when the liquid evaporates it leaves an abrasive film.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 01-28-2014, 09:06 AM   #10
bassman2's Avatar
Rick is correct, WD-40 is abrasive when dry so when you fire up the engine each time you are actually scratching the piston and inner sleeve lining. Do not recommend it as after run oil.
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 01-28-2014, 06:43 PM   #11
xrayracer1's Avatar
Yeah I heard someone tell me once that WD-40 can wreck the engine. Now I know why.
Old 01-28-2014, 09:09 PM   #12
Bundy_Bear's Avatar
What about Carby Cleaner or Brake Cleaner?
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 01-29-2014, 09:24 AM   #13
Default Brake Cleaner vs Bearings
Actually a different subject but did receive an interesting comment from a bearing source (discussion was focused on slot car bearings but I'm sure it applies) regarding the fact that he felt that brake clean was too agressive to flush out bearings (we can assume the same goes for the more agressive carb cleaner) and that motor spray would be safer.
Old 01-29-2014, 10:46 AM   #14
DarthRacer's Avatar
I'm going to +1 on the Marvel Mystery Oil. I started using it when I realized the Hobbico ARO I was using was the same stuff. Same color, smell, everything.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
