Cyrul's Break in Procedures
#122
I've gone through the first three tanks and I couldn't get the motor to run above about 115 deg. I had to lean it back out periodically and blip the throttle to get it to heat back up.
Kinda frustrated.
A I, did you happen to temp your motor when running it in that vid?
Kinda frustrated.
#123
Kinda frustrated.
Kinda frustrated.
#124
Kinda frustrated.
Kinda frustrated.
#125
IMO, an engine stand is a better way to break in an engine when using a WOT break-in method. You have a controlled load, the engine has no problems getting up to temp and you don't have to worry about putting a strain on any drive train parts. Yes, you do have to buy the stand (and possibly the prop starter, depending how comfortable you are using the chicken stick method), but it just seems to make life easier.
Just my 2 cents..
Just my 2 cents..
#127
Originally Posted by M7H
Rainer, the first couple of tanks are run in the car, not on the track..... I normally tighten my clutch, so there is nothing spinning, exept for the flywheel...
Last two engines I broke in (TZ & STI) were 5 tanks WOT on the stand, 5 rich tanks on the track and then I started race tuning it. I'm very happy with the results. Prior to that, I broke in a CRF and you don't use a WOT break-in method for that engine.
#128
Fellas I have an OS TG .12 going to break in, I was going to use the method by Josh here but wondering if anyone has any experience with the ABL liners used by these OS engines and if this method of break in would be still suitable for these liners. The ABL liner is supposed to break in easier or quicker so they say so not sure if running the 8 tanks would be to much.
#130
Amen to that!
Just do cyruls method it works, i was a skeptic but wanted to try it for so long. me and a mate built up a new sirio evo2 from old parts he had for a practice engine and broke it in using the WOT method...
we started to brake the motor in at 8am and ran it all day until about 5pm, only off the track top up reciever pack and it still has awesome pinch to turn over without a plug... should make some good power and be a good club/practice engine when it frees up some more
#131
a few things to do to keep the temperature up:
1). hairdryer
2). aluminum foil
3). mill half the fins off a spare head
4). if you have a sedan with a diff- grab a rear wheels to put some more load on the engine.
don't run the thing at 100F..... keep it at least 160F+.
1). hairdryer
2). aluminum foil
#133
Leave the bottom end needle alone. Just open the top end needle... you won't be on idle except for when topping off the tank.
This method works really well on Nova based engines. I just try to keep the temps up- as stated above.
When have run through the 8th tank start taking a look at the bottom needle. There's no use mucking with the bottom needle till you get the top end close to where you'll be running at race tune.
#134
#135
Ok...
Read the thread I understand how and why on the wot breakin.
However I am breaking in the engine in next week and it is still f@@#@ cold in Connecticut.
Heat gun get it to about 160f and start as listed for the cryul wot method.
Correct?
Correct?
