Blowing Plugs ???
Hi All
I am currently blowing plugs on a motor that has been rebuilt with new P/L/S and crank, bearings are good.
Tried O'donnell 97T but the coil is collapsing and then plug blows, should I go to 99T or should I add a 0.1 brass head shim.
I believe that if you add a headshim you loose some HP???? is this correct.
Motor is an 0.12 RB T10.
As I have said this is a rebuilt motor after s napping a conrod, so if the crankcase has been dented on the inside would that be enough to increase the compression. I've had a good look, flushed the motor out, inspected the bearings etc... and connot see any real damage.
Any suggestions, thanks!
And after changing the P/S/R set you always have to check the head clearance, maybe it is to low.
