Cold Plug More Power
I've been searching to find the theory behind cold plugs making more power?
I read [wikipedia, O.S. guide] all I got out of them is cold plugs make more power.
http://en.wikipedia.org/wiki/Glow_pl...odel_engine%29
http://www.osengines.com/accys/choosing-glowplugs.html
Colder plugs do cool down more betwen the combustions. With the next combustion the plug is colder so to create an ignition the compresion needs to be a bit higher. With other words: a colder plug shifts the ignition to a later moment.
With a shifted ignition you will get more rpm but if you correct the ignition back by lowering the button head you will get more compression giving more power.
