Old 05-28-2013, 05:02 PM   #46
Send a message via MSN to Rebellion
Originally Posted by DS Motorsport View Post
You can run the Orcan engines quite hot, at the Euros I was advised to tune them to 160C. This wasn't an issue at all, it was pretty hot though (40C).
For myself I tune them to 110C plus outside temp. So when it's only 10C outside I run it on 120C. It also depends on what kind of meter you use to temp the engine, the measurements can vary as much as 20C between different meters!.
Either run the C5TGF or C7TGH. The 5 for qualifying and the 7 for races.
Other plugs could work as well, like OS and Sirio but Orcan advises the use of Nova plugs.
Thank you DS Motorsport. I use for meter the temp Exergen DX501;
A few days ago I bought the combo you suggested in this post, I have no doubt if C or S version right now, I do not know if it's the SPEC 2013 or not, I know it's the MH version I I have been in contact with Alexander Hagberg and advised me to use the new exhaust (made by HIPEX) but do not know where I can buy it.
I would need to know the specific version, I think it is C but I'm not entirely sure
Thank you for your attention, I hope you can tell me more about the performance of these engines on track and I have no reference about these
Rebellion is offline   Reply With Quote
Old 07-31-2013, 05:57 PM   #47
HHH
HHH's Avatar
Default Engine Romance
After 3 great races and 1.5 gallons the engine is tested -- I love this GT3-C.
I showed before pics and here are pics now. I have only changed the conrod. It is running better than ever. Engine love!
HHH is offline   Reply With Quote
Old 08-01-2013, 08:51 AM   #48
Arahawak's Avatar
Trader Rating: 32 (100%+)
I see some detonation..
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 08-01-2013, 10:52 AM   #49
,run too hot
kyosho malaysia is offline   Reply With Quote
Old 08-02-2013, 12:33 AM   #50
HHH
HHH's Avatar
Just carbon from some bad fuel I had. Not detonation.
Don't be jealous of my engine now!
Old 10-01-2013, 08:19 AM   #51
How will these engines? I expect you to write a comment, I recently was talking to Bertram Kessler and com Alexander Hagberg and I have said that the new exhaust is what is giving better results, I just bought it and I came soon.
Mr Kessler also told me some settings for the engine to run a little more, and I practice in an area at sea level and I have to make a specific adjustment that Mr Kessler told me the engine combustion chamber
Old 10-01-2013, 08:51 AM   #52
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
im getting mine back from MH he did maintenance for me i have the S version
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 10-01-2013, 09:44 AM   #53
I have Orcan GT3 C MH version
Old 10-02-2013, 12:34 AM   #54
GREGORY!'s Avatar
which pipe do you mean?and what shim setting did they recoment?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 10-02-2013, 02:55 AM   #55
I have bought the exhaust Orcan OA1911, recommended by Bertram Kessler and Alexander Hagberg. The exhaust was still have not received it.
I currently run on a track that is at sea level and I have told Bertram that the engine was not running all that should run, Bertram then gave me some advice, I said the following:
You must put out to 0.10 and put in 0.15 it give from Nova Rossi
Or If You Have inside 0.30 you put out and give in 2x 0.10 and 1x 0.15 in end You have not You have 0.38 and 0.33 so you can close the top speed.
I was also recommended to use the glow plug Novarossi C7TGF
Old 10-02-2013, 06:51 AM   #56
HHH
HHH's Avatar
I absolutely love the C version.
I run at sea level with the 7F nova plug and shim .30 to .35 and 16% nitro fuel.
Can be tricky to tune and need to change the conrod frequently but the engine has power and revs everywhere.
What brand car and gearing are you using?
What are your clutch settings?
Do you run a lean or rich low end needle setting? How many turns out is your low speed needle?
Maybe I/we can help.
Sam
Old 10-02-2013, 08:29 AM   #57
I am using xray nt1 2013, and I'm using gear in first gear 17 and 60, and in second gear 22 and 54.
In the clutch using the clutch reverse of x ray with hard spring of xray, spring tightening to 0.8 mm.
The clutch hueco also 0.8mm, and the end play I adjust until practically have nothing to play and free to move the bell.I use setscrews in the flyweights and yellow clutch shoe.
Certainly in the document preparation engine engine washers MH brings me that I 0.33mm
Adjustment needles are not precisely tell as I take the motor will always 130 or 140 degrees
Old 10-02-2013, 07:58 PM   #58
HHH
HHH's Avatar
1. Your gearing sounds fine. Same as I use on most tracks (unless really large).
2. Try loosening the clutch spring to 0.4 to 0.5. When I use the xray hard spring or washer spring I find 0.8 to be too much. Gap and endplay sound fine.
3. I was asking about the low end tuning "turns in" because after Betram watched how I drive in Bangkok at the pre-worlds and worlds, he turned my low speed needle in all the way in and then backed it out only 1/2 to 3/4 of a turn. He then adjusted the high speed (richer) and made the idle high.
4. Temps of 130 to 140 C could be too high, too lean. When Alex Hagberg was here in Singapore last month and I was his mechanic--he was using Runner Time 16% and using my exergen temp gun (over the glow plug but not pushing down the bodyshell as Betram suggests for a more consistent temp measurement) Alex's engine was running 104C to 114C only. We had very high humidity and the air temp was 34C+. He TQ'd the race.
When I use VP Fuel or Byron my engine seems just nice around 115 to 120C (after 10 to 20 mins of racing). With Tornado a bit hotter at 125C.
I know comparing temps is not the best way because ther are many variables, but maybe these temps give you some extra information and reference points.
At the Pre-Worlds in Bangkok, after a 1 hour A main I saw Betram measure Dirk Wishnewski's engine temp at 120C at the end of the race using an exergen temp gun over the glow plug hole of the body, not pushing the body down.
Don't give up. The engine can be hard to tune but one you get it right it is very, very powerful.
Sam
Old 10-02-2013, 09:59 PM   #59
you will love it
WILLIAM PENDERGRASS
Old 10-03-2013, 03:53 AM   #60
Wou fantastic Reply .
The working temperature of the engine told me Alexander Hagberg, and I said that about 120 or 140 degrees.
I got in touch with Bertram Kessler because in my circuit the Novarossi Keep on passing me on the straight and those engines were running more than my Orcan.
I have not yet tested what Kessler tells me shims combustion chamber, I have to remove a shim 0.10mm and put 0.15 mm shim, that's what Kessler said in the email snippet that I have stuck to the post above.
I have to try the new exhaust and what he says of the shims combustion chamber and I have to see if the engine runs more.
how much shims bring your in the combustion chamber, exactly?
JQ Products - THE Car Beddo Nitro Off-Road 12022 09-24-2015 04:55 AM
