STS .28 pull-start engine
Old 04-11-2005 | 09:27 AM
  #121
Horatio's Avatar
Originally posted by pttf
ok i think i found the problem. I noticed when the engine is running there are bubbles in the fuel line which are not moving. So i gather there is lack of compression somewhere. So this should narrow the problem which is causing the engine to run high. Any suggestion's
Check your tank, lines and filters - a leak in any of these will result in bubbles - especially if you have one of those cheesy priming buttons - they always leak. Also check to make sure your fuel isn't foaming.
Then double check the engine is sealed, carb, backplate etc.
Horatio is offline
Old 04-12-2005 | 08:13 AM
  #122
dino.tw's Avatar
Nitro Tech
Originally posted by pk
Hi dino.tw!!!
I just got and installed my STS28 yesterday.
I just have two concerns....
1. When I was configuring the radio, There are times when the carb gets stuck when im attempting to go WOT. What i usually do is 'double clutch' the throttle, which seems to 'unstuck' whatever is blocking the slide.
2. On the CG image of the shaft starter, i noticed that the hole for the rotostart is at the side. Will this fit the savage? I mean, the savage's rotostart hole is on the upper left corner. I hope you could accomodate us Savage owners
Right now im pumping some iron and strengthening my pullstart arm as im about to break in the beast! haha!
I'm back! Sorry it's very busy lately.
1) If you feel the slide valve is not so smooth,most of the cases are stuck by the idle screw. The edge of the valve's groove may not smooth enough. Please take off the idle screw and check the valve's groove or the idle screw. I will ask our factory to check it again.
2)I will get the sample next week. And I will report to you how its going.
Thanks,
Dino
dino.tw is offline
Old 04-12-2005 | 08:24 AM
  #123
dino.tw's Avatar
Nitro Tech
Originally posted by skybolt58
Sorry ! But I wish I was kidding, I have been running Glow engines since 1973, I am sure I know how to tune a engine, cars/trucks/planes/boats/and helichopters. I have a lot of money in this savage! I doubt very much that the 3 speed would work, it needs more than 10% more speed to get past that losi lst. I thought for sure once I put that sts .28 in. and when I broke it all in I thought it was faster, But well it was faster than the stock .25! a lot of snott, But not enough for the losi lst. gearing is the main issue! the lst has a higher 2 speed ratio, and the diff's are higher geard. so I plan on buying a lst, and put my sts.28 on that.. then I can beat my son! thats the only way! on the lost ratio: is CB low 18 tooth, high 25 tooth, and the spur is 70t low and 63t high.. now that is some ratio's
WOW you ran glow engines since I was born 73".....
Have you tried to shorten the tuned pipe? Or another high speed tuned pipe? Tuned pipe to a 2 stroke engine is just like a turbocharge. The 2 stroke engine's power band is depended on the pipe.
dino.tw is offline
Old 04-12-2005 | 07:47 PM
  #124
jfc_tech's Avatar
i was walking & running already
STS buggy pipe would be nice...just a tot ere
jfc_tech is offline
Old 04-13-2005 | 01:14 AM
  #125
pk
Thanks,
Dino
Cool! Thanks dino!
The engine is wonderful!!!!
pk is offline
Old 04-14-2005 | 09:29 AM
  #126
Horatio's Avatar
How sad, a savage cant beat a losi! ;( I guess I wil be selling my savage and get me a stock losi, 55mph out of the box! we had it clocked about a hour ago...
How did you come up with this figure of 55mph for the LST?
Horatio is offline
Old 04-14-2005 | 10:26 AM
  #127
pininfarina's Avatar
LST out-of-box.. should be around 44mph
pininfarina is offline
Old 04-14-2005 | 11:11 AM
  #128
that must have been in low range! we had a local police here with a hand gun and he clocked it at 55, what can I say?
skybolt58 is offline
Old 04-14-2005 | 11:35 AM
  #129
Old 04-14-2005 | 08:32 PM
  #130
jfc_tech's Avatar
11 MPH difference
jfc_tech is offline
Old 04-14-2005 | 08:42 PM
  #131
jfc_tech's Avatar
This i quote from the Tech & Spec of the LST with XS3 & Mach .26 RTR.
this link
Speed: 40+ MPH
It should say there speed:50+ mph
jfc_tech is offline
Old 04-14-2005 | 08:45 PM
  #132
jfc_tech's Avatar
I really have to say this...i dont want to be caught by that police on speed trap on 90mph limit...when u only gone for 80 mph
jfc_tech is offline
Old 04-14-2005 | 08:46 PM
  #133
jfc_tech's Avatar
BUT of coz..if u have picture to prove it..then, my mistake, i apologize.
jfc_tech is offline
Old 04-15-2005 | 02:26 AM
  #134
Horatio's Avatar
Horatio is offline
Old 04-15-2005 | 02:27 AM
  #135
can I join in and watch?
