Old 11-26-2011, 09:09 AM   #1
Default Wahts your preference? (1/8 Onroad)
I tired different tune today, found an interesting points:
Track: High speed track
Plug: OD 99T
Fuel: Tornado 25%
Tune 1:
- Very lean LSN, HSN is on rich side.
- Gear shift very soon, even the 2 speed screws are very tight
- Good idle
- Temp is very cold, 78C - 85C
Tune 2:
- Rich on LSN, 15min turn in on HSN.
- Gear shift later than before
- High idle few sec, than normal idle speed, than stall.
- Temp is normal, 102C
- But the lap time is 0.5sec slower
So whats ur choice if you are in high speed track?
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 11-28-2011, 08:18 AM   #2
Plug: OD 99T
Fuel: Tornado 25%
Tune 1:
- Good idle
Tune 2:
what is the fuel consumption between this two setting,because quite important in a race
kyosho malaysia is offline   Reply With Quote
Old 11-28-2011, 12:04 PM   #3
Tune 1 is more fuel save, I dont know why.
Old 11-28-2011, 12:15 PM   #4
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Probably has to do with the idle.
Tune 2 isn't good because the idle speed shouldn't do what you describe.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 11-28-2011, 07:04 PM   #5
I think so, tune 2 is more stressful from what I heard.
Old 11-29-2011, 02:31 AM   #6
Roelof's Avatar
Send a message via ICQ to Roelof
With tune 2 there is a high chance your engine will go to lean on the end of the straight causing such high temperatures. Also the rich bottom end is causing loss in the corners and fuel milage.
Tune 1 does give a faster pickup and a for sure right setting on the HSN
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 11-29-2011, 06:04 AM   #7
Yes. I can feel the tune 1 make the engine run more relax then 2. will do some test to lean in proper way.
