Old 07-29-2012, 09:27 PM   #61
Is the Picco Torque Edo piston/liner set a direct replacement for the M7T engine? Looks the same but it's near impossible my neck of the woods to find an original replacement Reds piston/liner set but Picco Torque sets are aplenty.
peppernick is offline   Reply With Quote
Old 07-30-2012, 07:09 AM   #62
modhobby's Avatar
Trader Rating: 25 (100%+)
Not sure where you are located but we have one in stock here at the US Distribution location. Contact me if you need assistance.
http://www.reds-racing-usa.com/pisto...-5cc-m7t-tuned
REDS Racing USA
modhobby is offline   Reply With Quote
Old 07-30-2012, 10:25 PM   #63
stefan's Avatar
Send a message via AIM to stefan
Yes, the Picco P/S set will fit
stefan is offline   Reply With Quote
Old 09-24-2012, 09:45 PM   #64
Default M7T fuel supply problem
Anyone expereinced for that? Sudden fuel cut out and rich itself continously.
Everyday is different. Picco made me headache. T_T
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 09-24-2012, 11:09 PM   #65
bmain57's Avatar
Check your pipe, had a problem like that with a old pipe I had, changed pipe problem went away.
THANKS TO ALL MY SPONSORS...
MUGEN SIEKI USA, NOVAROSSI, KO PROPO AMERICA, PROTOFORM, AVID, FLASHPOINT FUEL AND TIRES.
bmain57 is offline   Reply With Quote
Old 09-30-2012, 02:55 PM   #66
RC-Netshop.dk's Avatar
Default REDS Engines
Hello everybody,
Glad to read so much good about the REDS Racing Engines. We have just received the distribution for REDS Racing Engines here in Denmark.
Unfortunately our season is over for this year, due to bad wheather. But we can't wait to fire these beasts up in the spring :-)...
If anybody in our part of the world needs REDS Engines or accessories please feel free to write: [email protected].
Remeber we do sell without VAT outside of Europe ;-)...
Thanks!
http://rc-netshop.dk/en/
Capricorn, REDS, CRC, Orcan, JP GIMAR, Ielasi Tuned, Tesla, JQ, Sanwa
RC-Netshop.dk is offline   Reply With Quote
Old 10-07-2012, 09:29 AM   #67
Yes I did, sometime the fuel stuck. Blip the throttle deep to clear some and will be fine, after 5 sec idle, its back to stuck again.
I've found the tip of NSH got damaged, but its brand new engine. T_T
Old 10-18-2012, 08:56 PM   #68
Default Bearings
Hi,
Anyone experienced any issue with the bearings?
Mine had to be changed after break-in and track tuning... aproximately 4 liters had gone thru the engine.
How are your bearings holding up?
Sam
sammies is offline   Reply With Quote
Old 10-20-2012, 12:29 PM   #69
Dear Sam
The bearings should normaly last a good bit longer.
If the clutch is set too soft, it will be slipping a bit. Slipping in a clutch cause vibrations wich will be transferred to the bearings, and then wear them out more quickly. Slipping in a clutch is more likely when braking an engine in then at racing.
Make sure the clutch engage fully, also when you break in engines, and you will observe that the bearings last much longer.
Best wishes; Jens
Originally Posted by sammies View Post
Hi,
Sam
jensroland is offline   Reply With Quote
Old 10-22-2012, 11:32 AM   #70
ND
Hi,
Sam
I've not had any problems with the bearings, so long as you use a good quality fuel. I have run probably 15 litres through without any problems.
ND is offline   Reply With Quote
Old 11-06-2012, 09:22 PM   #71
GREGORY!'s Avatar
h!can the rod from this engine used in a picco evo 3 on road engine?it is the same rod with torque if i am not mistake.also is the rod from M5T off road engine different than the rod from M7T engine?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 12-22-2012, 07:24 AM   #72
choisan's Avatar
what is the major difference of the latest m7 shown lately on the web?
choisan is offline   Reply With Quote
Old 12-22-2012, 01:28 PM   #73
GREGORY!'s Avatar
bigger stroke.
Old 12-22-2012, 09:04 PM   #74
choisan's Avatar
thanks! is it out to market already?
Btw, merry x'mas!
Old 12-25-2012, 05:56 AM   #75
wmay11's Avatar
Hi guys,
What is the difference in perfoemance between the M21, EDO 2012 and the Reds? Or are they all similar?
Thank you
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
