M Rossi REDS Racing M7T
Old 02-24-2012 | 10:08 PM
  #46
YLLIB's Avatar
Originally Posted by 5crossyourlip
Is the reds 2069 the same as the picco 2069
I have both and used both at the winter nats and they look the same. The performace I couldn't tell the differance either, maybe on a bigger track I could. Keep in mind the pipes are not made my each motor company.
YLLIB is offline
Old 02-24-2012 | 10:53 PM
  #47
stefan's Avatar
Pipes that have the same EFRA number are the same pipe.
This particular pipe is made by a company called Hipex and is available under different brand names: Picco, Sonic, Reds, Hipex and soon VOX.
stefan is offline
Old 02-25-2012 | 07:00 AM
  #48
NikoRacing's Avatar
Yeah what Stefan says is totally correct. In accord to Hipex the brand that he mentioned are allowed to mark the 2069 pipe with their different logos.
The EFRA number is the same so the pipes must be the same. You can only change the connection ring (for example Picco has a different gasket so it needs a different shape on the ring) and some few things but always staying in the homologation tollerancies.
NikoRacing is offline
Old 03-13-2012 | 06:02 AM
  #49
FF25510's Avatar
Default plug
guys,
other then Reds plug, what brand did you use most in this baby
thanks in advise.
FF25510 is offline
Old 04-06-2012 | 07:36 PM
  #50
Originally Posted by FF25510
guys,
thanks in advise.
Both Picco and Sirio plugs work with this engine.
peppernick is offline
Old 05-22-2012 | 01:58 PM
  #51
I received my new Reds tuned by an Italien guy in germany.
Engine works like a jet .A lot more bottom power
than the original. I will see to post some pics.
The engine looks amazing inside.
Blessed Speed is offline
Old 05-22-2012 | 02:03 PM
  #52
modhobby's Avatar
Cool. Keep us posted. Sounds interesting.
modhobby is offline
Old 05-24-2012 | 11:22 AM
  #53
Hello modhobby....
Yes I will do the pics this coming weekend ... I tried to do pics with my cellphone ...but the quality is not so good. This weekend my wife will turn back from holiday and she´s got the good cam with......
But I can say that the engine is amazing. I run today with a 48/45 16/20 gears and on this track no one use less than 49 because of very small corners and the shot out of the corner was incredible WITH NEW TYRES ( 76 / 69 )....topspeed as well and the engine is almost easy to tune. Not comparable with the original REDS.
the works are done on the crankcase, crankshaft and sleeve and the works are done very careful.
Be pacient for the pics...hope I can do it on sunday.
Old 07-21-2012 | 04:12 AM
  #54
Pattojnr's Avatar
how much fuel have you guys put through the motors before they lost even cold pinch ? ive run about 2lts through mine, and its lost all pinch. is this normal ? no marks or anything on the piston, or head button. its clean as inside.
Pattojnr is offline
Old 07-21-2012 | 03:52 PM
  #55
kickass's Avatar
kickass is offline
Old 07-21-2012 | 06:07 PM
  #56
Pattojnr's Avatar
Originally Posted by kickass
what do you mean by that ? '''
Pattojnr is offline
Old 07-21-2012 | 11:48 PM
  #57
Team Chump's Avatar
Have found the opposite, took forever to break in and is still very tight even after around 10L..... Makes me wonder about how consistent the piston to sleeve tolerance is from engine to engine??
Team Chump is offline
Old 07-21-2012 | 11:58 PM
  #58
Pattojnr's Avatar
i know of 2 other engines that took some fuel to run in properly.
this is why im thinking i have a problem with this engine. its supposed to be for Nats, and i really cant put faith in it now, knowing it took no time at all to run in.
when i say that, my M3T i have run in using same fuel same amount of fuel, and completely different engine as far as pinch is concerned. the M3T needs more run in.
Pattojnr is offline
Old 07-26-2012 | 02:06 AM
  #59
kickass's Avatar
All the reds engines are modded and hand matched from The factory, I have personally lapped 11 m3t piston and liners and found all of them pretty much equally matched. I assume the 21s get the same attention before they leave Reds factory. Id be getting a spare piston liner set if you are concerned as they are cheap. Hope you are not going to the nats with one engine for your 1/8 scale LOL.
kickass is offline
Old 07-26-2012 | 09:21 PM
  #60
stefan's Avatar
This ia a Picco Torque based engine, and since Picco introduced the Torque in early 2011, the break in time was drastically reduced.
We break ours in with 4-5 tanks of fuel and we love it.
Don't worry about your engine, all is good
stefan is offline
