Old 07-14-2011, 07:21 AM   #121
bsmooth's Avatar
Trader Rating: 17 (100%+)
How did the BP's do against the 'other' guys this past weekend at RAMS?
bsmooth is offline   Reply With Quote
Old 07-14-2011, 12:33 PM   #122
garen's Avatar
Qualified 4th, was running 3rd early in the main, had mechanical issues.
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 07-15-2011, 10:36 AM   #123
Default Fuel leak
I can feel the power even running still rich after break-in today.
But many fuel spill out from carb. neck, back plate, HSN shim. Any ideas? thx!
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 07-15-2011, 12:16 PM   #124
I do use teflon tape with exellent results everywhere.Had used red RTV silicone at back plate and carb neck with the same results but it is not as clean as the teflon tape.Just don't overdo it with the teflon tape on HSN housing for sealing the HSN shim so you won't brake it.
dsond is offline   Reply With Quote
Old 07-15-2011, 02:35 PM   #125
Yeah!!! thx! lol
Old 07-15-2011, 03:36 PM   #126
garen's Avatar
make sure the screws are tight and the high speed needle housing is also tight.
Old 07-16-2011, 07:32 AM   #127
I've found the lower shim is a bit over-size, now is fine.
But I like the engine, sound awesome!!!!!
BTW, what's the temperature range about this engine?
And, how much copper shims for the turbo head in standard setting?
Old 07-16-2011, 08:36 AM   #128
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
so what did you do to fix it, sounded like u had backplate leaks as well, or did you not, id like to know, thanks
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 07-16-2011, 09:52 AM   #129
use telfon tape, really works. easier control then silicone sealant.
Old 07-17-2011, 09:36 AM   #130
Default Engine temperature
FYI, I have my tune done finally, the engine run pretty well in high rpm, the temperature is 107C, run time 4:45/tank.
Old 07-19-2011, 09:51 PM   #131
C-Trickle's Avatar
I've been looking into a BP engine for my Kyosho GT car. I'm not sure which would be the one to get though. It weighs in at 3520 grams right now. It should be down to about 3350 in the next couple weeks. I'm not sure which BP engine would be up to the task of lugging this beast around. Maybe the 735RT or go with one of their off road engines?
Any input is appreciated.
C-Trickle is offline   Reply With Quote
Old 07-24-2011, 09:12 PM   #132
garen's Avatar
I would think an off road motor would be better, so I would suggest one of the 3 port buggy engines.
http://www.amainhobbies.com/product_...ost-Port-Turbo this should work well and meet most 'spec' rules around the US.
Old 07-25-2011, 01:42 PM   #133
C-Trickle's Avatar
Thanks, I was kinda leaning towards to off-road engines. I know the on-roads have a tough time getting this heavy pigs rollin'.
Old 07-25-2011, 10:11 PM   #134
Default Conrod order
Anywhere else can order the conrod? A Main is out of stock, any shop world wide I can order the conrod excpet their head-office in Italy. The shipping cost is crazy 250 EU to HK for 3pcs conrod which costs only 75 EU
Old 07-26-2011, 06:52 PM   #135
Trader Rating: 24 (100%+)
Interested in a good offer check this....http://www.rctech.net/forum/r-c-item...ml#post9443446
Team Associated TC7.1/HW XR10 Stock Spec/HW Bandit 10.5T/Arrowmax LP 52000 7.6v
IVAN RM is offline   Reply With Quote
Clockwork Racing Engines and Products... Maximo Offroad Nitro Engine Forum 8424 07-29-2015 03:10 PM
