NovaRossi Engine
Old 10-22-2010 | 09:50 AM
Default NovaRossi Engine
Guys I want to Buy NovaRossi engine and I see that they have 2 engine is good
bout I don’t know what is the better so I need help to can know witch on I get and better than the anther
1st one is: Novarossi FLASH 21
2nd one is: Novarossi FLASH 21 SPECIAL "TUNED"
So please I want to know what is there better to get it
Speeedy is offline
Old 10-22-2010 | 10:06 AM
wingracer's Avatar
There are more than 2 choices.
The special is essentially a factory mod. It's probably the best "stock" motor out there, especially on big tracks.
I actually prefer a good modded 35+21 to any of the flashes. More bottom with almost as much top.
If you're not an A-main driver or run on tight or parking lot tracks, don't waste your money on either. Get a Kangaroo. Cheaper, nearly as fast and the reigning ROAR Nats champ so it can definitely get the job done.
wingracer is offline
Old 10-22-2010 | 01:29 PM
The novarossi flash .21 special "TUNED" is factory modified/tuned. Which should be much better than the regular non-special "TUNED" version.
And yeh! a+++ for the novarossi kangaroo, great bottom end and great top. The best bang for buck!
yappy is offline
Old 10-23-2010 | 06:58 AM
Man can u give me the site for the engine that u talk about ??
and i need to use it in my on road kayosho car so still novarossi is good ??
or i should change and get anther engine ?
Speeedy is offline
Old 10-23-2010 | 07:02 AM
wingracer's Avatar
Novarossi are the best. 35+21, Kangaroo and others are Nova motors. I'll find some links for you.
Old 10-23-2010 | 07:04 AM
ok so u prefer to em to order it right ??
i find it in 649 $ are this good price or there is better
i;m talking about the tuned one
Speeedy is offline
Old 10-23-2010 | 07:07 AM
wingracer's Avatar
http://ashfordhobby.com/detail.aspx?ID=5329
Kangaroo
http://ashfordhobby.com/detail.aspx?ID=5324
Flash Special Tuned
http://www.serpentamerica.com/shop/p...&cat=80&page=1
Old 10-23-2010 | 07:10 AM
wingracer's Avatar
Like I said before, Flash Special Tuned is the best out there but not by much. Unless you are a top amain driver, get a Kangaroo or something like it for less money and use that dough to buy more tires, fuel and parts to do more racing. If you can't win with a Kangaroo, a Flash isn't going to make the difference.
Old 10-23-2010 | 07:17 AM
wingracer's Avatar
And if you just HAVE to have the HP but want to stay under $500:
http://www.murnanmodified.com/produc...roducts_id=260
Or even less money (still made by Nova):
http://www.murnanmodified.com/produc...roducts_id=568
Old 10-27-2010 | 12:38 AM
Hi guys,
What modifications are performed by Novarossi to a "special tuned" Flash compared to a normal Flash?
Spent alot of time googling, can't find an answer.
ace16 is offline
Old 10-27-2010 | 03:09 AM
Roelof's Avatar
The crankshaft is (so far I know) with the tuned the main difference. Tonight I will see both engines to messure it up, then I know the real differences.
For sure with the special Flash a CNC piston is used and not the Microcasted one.
Roelof is offline
Old 10-27-2010 | 03:14 AM
Thanks Roelof,
Let us know what your findings are.
ace16 is offline
Old 10-28-2010 | 06:24 AM
Roelof's Avatar
Originally Posted by ace16
Thanks Roelof,
No Flash special tuned, only the older 2009 models. Between te flash and the tuned version there is not much difference in the crank timing but a huge difference with the exhaust port (the highes so far I have ever seen). Also the turbo scoop on the crankshaft was with the tuned version much larger and rounder and with the normal version quite stock.
One of te 2 was new so the guy could not tell the difference but I expect more RPM with the tuned version which may have to be lighter geared
In the attachement all engines from yesterday
Roelof is offline
