Sirio S12 XXX VK problem
If you provide the information below, maybe someone can offer some suggestions:
How did you break-in the engine?
What is your head clearance?
What % nitro and plug are you running?
What are the HSN and LSN needle settings now?
What is your idle gap inside the carb?
Are you running the car at sea level?
How did you break-in the engine? Just let it goes and screw the HSN
What is your head clearance? No change, default setting
What % nitro and plug are you running? 5%
What are the HSN and LSN needle settings now? Someone helped me to tune. So It's, HSN 2 1/2 turn from close, LSN 1 turn from close.
What is your idle gap inside the carb? I saw it around 1mm and little more
Are you running the car at sea level? on the hill
Not stable could be other things:
- bad sliding carb
- binding on the throttle movement at the servo (use an extra return spring)
- bad servo
- bad neutral pont servo (trim)
- leak in exhaust system
- leak in tank (cap)
- leak in fuel/fressure lines
- bad sliding carb
- bad servo
I suspect the carb is factory defected, the servo is new and in netural prefectly. exhaust, tank and tubes r fine when I use the other engine.
If the carb is binding you should disassemble the carburetor.
Probably the slide has some flashings from machining.
You could use some Scotch Bright (Steel wool) to remove the flashings. Then smooth it with some polishing compound.
Yes, I did and re-asemble the carb, smooth now! Thx!
