About conrod
Old 01-08-2010 | 08:43 AM
FF25510's Avatar
Default About conrod
an old question, when should i change the conrod of a .21 NR base engine. thanks all
FF25510 is offline
Old 01-08-2010 | 11:14 AM
ugglasdav's Avatar
i would say every 5 liters of fuel you should change it
ugglasdav is offline
Old 01-08-2010 | 12:00 PM
wingracer's Avatar
If you run only short tracks, I've had rods outlast the rest of the motor. Long tracks, change often.
wingracer is offline
Old 01-08-2010 | 12:09 PM
MRX4XXXX's Avatar
Do you have experience about the Novarossi new piston pin holder springs? I have onroad .21 PLUS engine and the holders look like letter C. All my other engines have the holders looking like letter G.
Are the C-shaped ones any different to remove and do I have to use them or can I use the G-shaped ones also??
-MRX-
MRX4XXXX is offline
Old 01-08-2010 | 12:28 PM
FF25510's Avatar
thanks guys,
it's hard to make decision on picking up a new engine, i have an OS and a RB classico 9 and i'm thinking to pickup one more. i'm target on N21-7T or S21WCS09.(RB and NR parts are the most available here) after that, maybe i can try the top line engine.
FF25510 is offline
Old 01-08-2010 | 12:38 PM
Roelof's Avatar
-MRX-
The C-clip can only be used in pistons with a slot in the side of the pisten, with older pistons without a slot it is very difficult to remove them.
Otherwise you can use the G-clipin pistons with a C-clip.
The extra material on the G-clip is weight and can create a lot of G-force on hugh RPM, even that much the clip can loosen itself.
Roelof is offline
Old 01-08-2010 | 12:47 PM
wingracer's Avatar
Originally Posted by FF25510
thanks guys,
Change OS rods constantly. Good motors but rod failures are common.
WCS09 is a great motor for the price.
