Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Scratched Piston and Sleeve question? >
Old 10-08-2009 | 04:50 PM
  #16
Racecrafter's Avatar
Hows the rear bearing look?
Something was definately rearing its ugly head into the boost port.
Racecrafter is offline
Old 10-08-2009 | 05:39 PM
  #17
cdelong's Avatar
new engine time.....
cdelong is offline
Old 10-09-2009 | 02:46 AM
  #18
g-wan's Avatar
why nt try from sts dragon p/s 3 port? i use it for my v12 and it run very well,even my novamega 12 using the sts dragon 5port and my novamega sx21 using caster racing,its much cheaper..just suggestion..
g-wan is offline
Old 10-09-2009 | 08:41 AM
  #19
Gonzo RR's Avatar
Rear bearing looks good! here's a couple of pics
Gonzo RR is offline
Old 10-09-2009 | 08:48 AM
  #20
Gonzo RR's Avatar
Originally Posted by GMartinez
Try reaching out to Murnan he might be able to help you out since he does a lot of mods on RB's He might have a P/S set
I send an email yesterday and this morning got a response! great customer service! I'm considering letting Uriah modify this motor if I decide to buy new P/S set.
I tried swaping pistons with the V12 unfortunatly they are not the same. V12 piston won't even fit inside the R3 sleeve.
Gonzo RR is offline
Old 10-09-2009 | 08:51 AM
  #21
wingracer's Avatar
That's not a bad idea since the motor wasn't very old. A new P/S, Uriah's mods and you have a killer motor for a bit less than buying an all new one outright.
wingracer is offline
Old 10-09-2009 | 09:01 AM
  #22
captian's Avatar
that may not a bad idea
captian is offline
Old 10-09-2009 | 09:14 AM
  #23
Gonzo RR's Avatar
Oh I know! it was actually my idea since I have the V12 just laying around...
Well the cranckcase, carb., P/S, crankshafts are very different between V12 and R3 I just figure I would be able to change pistons since they are both RB engines. To my surprice the R3 piston is slightly smaller than the V12
Gonzo RR is offline
Old 10-09-2009 | 08:12 PM
  #24
Gonzo RR's Avatar
Check out this vid of an RB R3 Murnan Modified engine
http://www.youtube.com/watch?v=8huEwfLEI8E
Gonzo RR is offline
Old 10-15-2009 | 12:48 PM
  #25
Gonzo RR's Avatar
Engine sent to RBMODS for inspection and Modification!
Gonzo RR is offline
Old 10-28-2009 | 03:18 PM
  #26
Gonzo RR's Avatar
Hello everyone! Just wanted to share some pics of my R3 modified by Rick Brake! he really hooked me up, let's just say I paid less than if I had purchased a new P/S set.
He installed a new 5 port novarossi Piston and Sleeve, new front bearing, modified crankshaft, sleeve.
Gonzo RR is offline
