Old 04-12-2005, 09:32 AM   #766
WeatherB's Avatar
Thanks got it going...
WeatherB is offline   Reply With Quote
Old 04-13-2005, 02:37 PM   #767
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally posted by WeatherB
Hey guys,
I purchased one of these engines from my LHS yesterday...
I will be running 15% nitro, do I need to remove any head shims? I remember seeing somewhere that I need to remove all the headshims except the copper one.
Can anyone confirm this?
tnx
i got mine in the mail today!!
Old 04-13-2005, 05:59 PM   #768
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
[QUOTE]Originally posted by Marcos.J
i got mine in the mail today!! [/QUOTE
about time you bought a new ENGINE
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-13-2005, 09:06 PM   #769
Super Moderator
Marcos.J's Avatar
[QUOTE]Originally posted by 20 SMOKE
tell me about it!!!
Old 04-13-2005, 09:58 PM   #770
WeatherB's Avatar
So far this engine has been awesome, I ran about a tank of gas through it so far.
It did something really weird around 1/2 tank though. The engine's RPM became unstable and increased from a quiet idle to about 1/4 throttle (estimate) by itself (without carb input).
I shut it off and let the engine cool, it was fine for the remainder of the tank.
Engine temp was 180
Old 04-15-2005, 03:10 PM   #771
Dreddlox's Avatar
What method did some of you use to break the engine in? The "Goose" makes its maiden voyage this sunday so I wanted to start off right.
Dreddlox is offline   Reply With Quote
Old 04-15-2005, 03:57 PM   #772
WeatherB's Avatar
Everyone will tell you something different...
But personally I do this:
Tank 1,2 - Leave the engine at factory settings and start it up. Let it sit there and idle. Once finished, let the engine cool with the piston at BDC (bottom).
Tank 3-10 - Drive the car around going about 1/4 - 1/2 throttle only. You want the engine to run at different rpms.
Tank 11 - start leaning slowly.
The breakin process will last about 1 - 1.5L of fuel.
Old 04-16-2005, 07:46 AM   #773
Dreddlox's Avatar
Is O'donell's 30% ok to use or am I better off with 20%? I'm located in the NYC area if that makes a difference.
Old 04-18-2005, 11:32 AM   #774
jrabbito's Avatar
Weather B,
You do that with your servos reversed? Josh Cyrul's tips are the best I have found. Try his method...it works.
http://www.cefx.net/tips/nitro/break-in/index.php
Good luck!!
john
jrabbito is offline   Reply With Quote
Old 04-18-2005, 12:08 PM   #775
WeatherB's Avatar
Nope, throttle servo is not reversed. Only steering.
Personally I wouldn't want to start a brand new engine and give it full throttle. That's just me though. But he makes a good point about more fuel = more lubrication and properly seating the parts.
Old 04-18-2005, 07:29 PM   #776
GMartinez's Avatar
Trader Rating: 85 (100%+)
I break in my engines with 20% & then for racing I use 30% & got a lot out of them.
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-27-2005, 09:30 AM   #777
FRP
now there's R3 SiR Edition! should have pretty good performance!
SiR R3
FRP is offline   Reply With Quote
Old 04-27-2005, 03:02 PM   #778
jrabbito's Avatar
I have seen this motor run at a recent test. Great performance.
John
Old 05-03-2005, 10:03 PM   #779
Quietroit's Avatar
Default shim
I'm run 30% fuel with rb 6 plug is it safe to remove silver or copper. And what was happen if i do remove one of the shim. And what is a good clearance for 30% fuel
Quietroit is offline   Reply With Quote
Old 05-07-2005, 04:26 AM   #780
RayJ's Avatar
Default Shims
Most engines come from the factory shimmed to run at a MAXIMUM nitro content of 30%. If your running I believe an RB6 plug which i believe is a hot plug you run the risk of detonation in warmer weather. If you remove any one of these shims you will probably risk detonation at sea level, especially in warm summer temps. Motorman knows more about this, but I personally would leave it alone.
RayJ is offline   Reply With Quote
richey Excellent Takt Buyer/Seller dispute and Feedback discussion forum 1 11-26-2005 09:27 AM
Richey Mt 12 Still New Jon Carlson R/C Items: For Sale/Trade 2 09-07-2004 04:56 AM
Richey RTU engine MT12 TexasRacer R/C Items: For Sale/Trade 0 03-08-2004 09:32 AM
RD/Richey racing engine update Motorman Nitro On-Road 38 12-07-2003 12:14 AM
Dennis Richey RTU MT12 Engine Dan R/C Items: For Sale/Trade 14 12-15-2002 10:11 AM
