Old 05-20-2004, 04:04 PM   #241
Motorman's Avatar
The website is still very crude and those prices are not accurate in any way on tires. I need my web guy to update things there alot as we set it up and Its just laying there at the moment untouched.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 05-20-2004, 04:50 PM   #242
whynot's Avatar
Trader Rating: 18 (100%+)
I have a question I have a brand new jp .21 worlds motor 2002 and I will be running 20% odonnel fuel.How much shim thickness should I have?I think it has around .5mm -.54mm in it right now.also how many different thickness shims are there? thank you very much.
mike wannett
whynot is offline   Reply With Quote
Old 05-20-2004, 05:32 PM   #243
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
mike wannett
Depends on where you get your engine from. If you get it from U.S through authorized dealer then it should come with 0.6mm headshim (shim for 20%).
I was told if you get it directly from Europe, then it comes with 0.4mm (for 16%).
I run mine at 0.7mm head shim just to be on the safe side.
Just FYI, it you dont haev enough head clearance then it will be over compressed and you will crack your piston or suck a plug in there!
Ah10 is offline   Reply With Quote
Old 05-20-2004, 07:33 PM   #244
Motorman's Avatar
It should have a the following in it
silver .010 shim in thousanths
copper .008 shim
copper .004 shim
remove the .004 as you are in the midwest I believe and you will generally run a #7 plug (80 degree median temp)
PS put the alumunium shim to the liner. it will be the last one to go on.
Old 05-20-2004, 07:41 PM   #245
Motorman's Avatar
Stormperson YGPM
Old 05-20-2004, 08:20 PM   #246
tallyrc's Avatar
when will the updated prices on the tires be posted. are you not selling 30mm touring tires?
tallyrc is offline   Reply With Quote
Old 05-20-2004, 08:28 PM   #247
whynot's Avatar
Thank you very much guys .I will break in the motor tomorrow.
mike
Old 05-22-2004, 03:26 PM   #248
ottoman's Avatar
Dennis... or anyone
What do you think (in general) about a ceramic coating on the piston of these motors? I work in a shop that builds sprint car engines and we coat the pistons in house so I can do it for free. Also we have a coating that we use on lifters etc to reduce wear... I was thinking about coating the crank pin...
ottoman is offline   Reply With Quote
Old 05-22-2004, 04:29 PM   #249
Motorman's Avatar
otto its all good there
Old 05-22-2004, 10:11 PM   #250
GAMBO94's Avatar
Hi,
can anyone tell me whats the name of the red epoxy that is used in modified Engines crankshaft,,or what type of product is it....any help will be appreciated.
GAMBO94 is offline   Reply With Quote
Old 05-23-2004, 09:36 PM   #251
tallyrc's Avatar
roar states that you are allowed to run ceramic bearings, and that is it. no other ceramic part are allowed in an engine.
Old 05-24-2004, 05:31 AM   #252
Taylor-Racing's Avatar
I'd like to know also, please.
Taylor-Racing is offline   Reply With Quote
Old 05-24-2004, 06:49 AM   #253
EdwardN's Avatar
Originally posted by ottoman
Dennis... or anyone
Hi Jim.
We tryed it in the past to use ceramic coating on sleeves and piston-didn't work as good as we have now ( AL on Chrome).
Cranck pin coating might defenetly work. What is hardness of that coating? What is size of microcracks ( there will be microcracks)? How thick is coating? ( in your shop)
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 05-24-2004, 05:16 PM   #254
Motorman's Avatar
I would only use ceramic on the piston crown, stay away from anything on the skirts and cylinder bore. Diamondlike (the great JP,RB secret)works well on the crankpin and wristpin though you will need to resize the bushings to compensate, and teflon benefits other areas.
Old 05-24-2004, 06:14 PM   #255
stefan's Avatar
Send a message via AIM to stefan
I had very good luck with my hardchromed crankpins so far, thanks to Edwards advise..
stefan is offline   Reply With Quote
richey Excellent Takt Buyer/Seller dispute and Feedback discussion forum 1 11-26-2005 09:27 AM
Richey Mt 12 Still New Jon Carlson R/C Items: For Sale/Trade 2 09-07-2004 04:56 AM
Richey RTU engine MT12 TexasRacer R/C Items: For Sale/Trade 0 03-08-2004 09:32 AM
RD/Richey racing engine update Motorman Nitro On-Road 38 12-07-2003 12:14 AM
Dennis Richey RTU MT12 Engine Dan R/C Items: For Sale/Trade 14 12-15-2002 10:11 AM
