Palmaris engine thread
#1741
Hi guys.
Finaly we did translated small script to calculate timings and it can be found at http://www.palmarisracing.com/Timing_Calculator.htm
If anybody has questions how to use it, please feel free to ask.
Best regards
Edward
Best regards
Edward
#1742
Hi Edward,
I'm finally starting to run nitro again. Now that I have to run 16% Nitro, what shimming do you recommend for the BRB and AAC sets I got from you. In the states with 30% I ran one alu shim and one copper shim. Should I just remove the copper shim?
the crank are 215 degrees on both engines.
Btw, did I ever tell you about my last race in the US, which was my first race with the AAC engine?
This thing was an absolute monster, but during practice, a huge nail standing out of the asphalt, ripped my crankshaft into two pieces. Remember Cyruls 1/8th scale at Ft.Myers in 2004? It looked just like that.
Are you still making AAC sets? Also, I don't see you engine mentioned lately. Are you still running them or did you stop that project?
Tanks,
Stefan
Tanks,
Stefan
#1743
Originally posted by stefan
Hi Edward,
Tanks,
Stefan
Hi Edward,
Tanks,
Stefan
Nice to hear that you are back to racing. I hope it will be as good as it was in States.
I will sugest to use 0.3 mm shimming for BRB and 0.2 for AAC.
We don't make AAC anymore, they are good fro pretty cold weather, but BRB is good for any ambient conditions.
We are preparin new engine and we will start testing it on the end of this week. It is absolutly new design, but it is conventional type.
Edward
#1746
Originally posted by Top Gun 777
Hi Tommy.
I checked many times and it is working perfect-this is not new calculator-it was just on Russian, so it takes time to translate it, but the formulas is till the same.
Edward
Hi Tommy.
Edward
#1748
Procedure to use timing calculator
Ok, I got an idea why there is difficulty.
1 step is to enter piston diameter (13.8 for example)
2 step is enter stroke (14.04 mm for example)
3 step is enter exhaust height ( 5 mm for example)
4 step is enter difference between exhaust height and transfer height (2 mm for example) Always when engine is designed, designer are interested in difference between exhaust and transfer-this is dictating pipe length. So from exhaust height needs to be subtracted transfer height.
5 step is pressing left bottom button, which says “calculate timings and capacity”
Second possibilities is reverse calculating:
If you know what timing you want to put, just put it and press right bottom button which says calculate exhaust and transfer height if timing known”
Please try this way, I hope it will help.
#1749
What problem do you see? It is not working or give wrong ##?
#1751
i have check it,
with the firfox browser it works not, but with the ie 6 it works fine
dieter
dieter
#1752
Originally posted by 4racer
i have check it,
dieter
i have check it,
dieter
#1753
yep IE6 works.
so easy now.... what about induction timming , this easy?
#1754
This is GREAT!! Thanks for making this avalible for the public. Killer tool.
#1755
Ed,
I read in some post here that you said that it is important that ports close exactly the same all over the high side of the exhaustport. Novarossi engines have a little V-cut on top of exhaust any idea why?
