Like Tree195Likes
Novarossi engines thread
Old 09-14-2011 | 12:37 AM
  #4156
Mugenville's Avatar
Where can i get hold of a rod and piston pin for a 353 08, any help would be great
Mugenville is offline
Old 09-14-2011 | 01:31 AM
  #4157
Chickentrader's Avatar
You would probably get one from P.J. at http://www.radicalrchobbies.com.au/. Give them a ring. Let me know if P.J. cant supply you with it; and I'll look through my old engine parts, there could be some new ones there.
Kindest regards,
Lars.
Chickentrader is offline
Old 09-14-2011 | 01:39 AM
  #4158
Mugenville's Avatar
Kindest regards,
Lars.
Thanks for the help, i bought this new and only just started running it in, have put about 10 tanks through it now without it seeing the track yet
Old 09-14-2011 | 03:22 AM
  #4159
try Ari fron Northside hobbies also. he has pretty cheap Nova stuff.
put it ont he track Rob. it will break in better when it runs at something closer to race temps. after 10 tanks you are more than ready to get it up to 110 degrees or even more. get some heat into it, they run better when broken in like this. As long as you have good quality fuel, the oils should provide allt he lubrication and protection needed.
TomB is offline
Old 09-14-2011 | 03:37 AM
  #4160
Mugenville's Avatar
Yeah i know that tomas, had a few tanks running up and down the street, just wanted a spare rod to change after, would any of the 09 gear fit in it
Old 09-15-2011 | 07:45 PM
  #4161
Originally Posted by DJ_Shakespear
Don't reduce the shimming, it would only cause problems instead of solving any. Adding .1mm usually moves the power up, but it isn't guaranteed, plus you would lose some bottom end power as well.
A shorter manifold should give you more RPM, at the cost of losing some bottom end power. A different pipe could also make it better all round.
Carefully dremelling the exhaust port to make it open for longer can do the same thing as a shorter manifold, but this is a permanent modification and you could possibly ruin the engine if it isn't done correctly or carefully
You could also go a little leaner (if there is room for it) to get more engine speed, or you could change plugs to one slightly colder, but this would lose a little off the bottom end, and could also make it hard to idle nicely.
It's a lot of trade-off's to get more top-end, otherwise there's isn't a great lot to do.
Thanks!
Johny is offline
Old 09-20-2011 | 10:39 AM
  #4162
Last weekend I run in my new Novarossi 353 Race.12S, after 900ml fuel the frontbearing was damaged.
Did you also have done those experiences?
SebO is offline
Old 09-20-2011 | 03:31 PM
  #4163
blis's Avatar
Just ordered a Conroad for a 353 08 PLus 2 - RadicalRC - Novarossi 07602 Conrod $39.95
blis is offline
Old 09-21-2011 | 05:03 PM
  #4164
hey mate ive got a murnan modified crankshaft for a 353 08 if you like? its been sitting in an oiled bag in my toolbox. you can have it for $30 bucks. i can use the money to pay for fuel to the nationals.
i miss the 353 08 it was an animal engine
mrgsr is offline
Old 09-22-2011 | 06:01 AM
  #4165
Mugenville's Avatar
NP i'll grab it, shoot me a pm
Old 10-06-2011 | 07:13 AM
  #4166
Can anyone guide me on how much shims to use for 25% fuel ?
AdrianOngs is offline
Old 10-06-2011 | 07:24 AM
  #4167
Roelof's Avatar
All .21 engines are set to 25% and all .12 engines are set to 16% (booth will work fine with +/- 5% nitro content.
But you have to tell more about your engine....
Roelof is offline
Old 10-06-2011 | 07:28 AM
  #4168
Novarossi PT .21
How much to shim, or just leave it the way it came ?
Old 10-06-2011 | 09:16 AM
  #4169
Roelof's Avatar
That engine is normally set for 25%, if you did get it new then just leave it as it is.
Roelof is offline
Old 10-07-2011 | 12:06 PM
  #4170
Do anyone noticed that the fuel consumption for nova PT 12 is much more higher than nova FLASH 12,FLASH i can run 6 min with engine temp 125 cel but PT i only able to make 5min30sec with engine temp 135 cel.
maybe engine tuning problem?
kyosho malaysia is offline
