Like Tree195Likes
Novarossi engines thread
Old 02-19-2009 | 03:28 PM
  #3046
wingracer's Avatar
The long bodied plugs wont hurt anything. The extra length is above the taper, it will still seat flush. They are great in weird weather conditions like cold and humid. They can really help the idle on a temperamental motor.
wingracer is offline
Old 02-19-2009 | 07:37 PM
  #3047
NitroWD's Avatar
Default 08 353 vs 3sct
hi guys,
parts like rod, P/S, crank are interchangable between the 353 and 3sct right?
actually what's the main differences between them?
will 3sct tuned be better than the normal 353?
cheers.
NitroWD is offline
Old 02-19-2009 | 11:48 PM
  #3048
aussies1129's Avatar
hey i just found out that the Jovanovics are using those plugs and so does a local nova guy here and someone said they are good in humidity so that will suit me
cheers
Originally Posted by NiTrO BoOsTeR
what i have found out, the performance wont be as good as it would if you were using an F. also the C is a touch longer. so im gonna trade a mate of mine who owns a hobby store and races off-road, my C6TGC's for either
C7TGF's or the C7TF
also with the 7 it will be easier to find a sweet spot. and it will run alot smoother.
aussies1129 is offline
Old 02-20-2009 | 12:38 AM
  #3049
NiTrO BoOsTeR's Avatar
Originally Posted by aussies1129
hey i just found out that the Jovanovics are using those plugs and so does a local nova guy here and someone said they are good in humiodity so that will suit me
cheers
argh k, well if they dont damage the engine, but im gonna try the 7's and ill tell u how they go, what i have been told is that using 7's will allow the engine to go faster.
NiTrO BoOsTeR is offline
Old 02-20-2009 | 03:51 AM
  #3050
Originally Posted by NitroWD
hi guys,
cheers.
see posts below, the 353 is a higher rpm engine good for fast flowing tracks and the 3sct tune good bottom great for alot of stop start tracks but for club racers both engines will get you a win!
cheers
Old 02-20-2009 | 03:52 AM
  #3051
thanks for that info!
cheers
Old 02-20-2009 | 04:10 AM
  #3052
stefan's Avatar
hi guys,
NOPE!
The 353 has a different crank with a different size crankpin. Therefore it also has a different conrod (#7602), which btw, is almost twice the price of the regular conrod (#7601) which is in all other .12 NR engines, including the 3SCT.
stefan is offline
Old 02-20-2009 | 05:15 AM
  #3053
keavze's Avatar
so...353 got better top while 3sct got better bottom.
which pipes match the engines best? 2630 with 5fins?
keavze is offline
Old 02-20-2009 | 05:20 AM
  #3054
NitroWD's Avatar
Originally Posted by stefan
NOPE!
thanks stefan
by the way, how does the 3sct Tuned stack up against the stock 353?
which pipe combo will be best for medium large track with a 70m straight?
NitroWD is offline
Old 02-20-2009 | 05:27 AM
  #3055
lil-bump's Avatar
hi guys,
cheers.
The connecting rod on a 3sct and 353 are different. These are not interchangable
lil-bump is offline
Old 02-20-2009 | 05:28 AM
  #3056
stefan's Avatar
thanks stefan
The SCT with the Max 2602 pipe and the longest gear will be ballistic, also on long straights.
The 2630 pipe is also good, but makes it a bit more thirsty..
stefan is offline
Old 02-20-2009 | 05:29 AM
  #3057
stefan's Avatar
What I said!
stefan is offline
Old 02-20-2009 | 05:43 AM
  #3058
NOPE!
oops my mistake so the piston and sleeve are interchangeable yes
Old 02-22-2009 | 06:02 AM
  #3059
well i have put about 2L on the engine and i can just turn it over by hand with the plug in, and there is no play in the rod, i got a big race this weekend so ill check it for play after then. dont run the C6TGC in ur 3SCT because i think it will damage the engine
plug wise the ones we should have got at are the C6TGF/C&TGF/C5TGF. if you can get the O'donnell 97's or run the C#TGF or the older C#TF.
by the way how is ur 3sct going, have you run it in, and if so can you turn it over by hand with the plug in it.
Mitchell
update I ran the 3sct in today with the #5 original plug and then put in the 6TGC and it idled unbelieveable!! and not to mention it ran ballistic but track run time with a 5fin header and 2630 was about 5.50 first time user I have to say that novarossi engines are really well engineered!
cheers
Old 02-22-2009 | 07:59 AM
  #3060
musti72's Avatar
Hi everyone,
I have recently purchased two plus 12-3sct's from my lhs. I opened them for checking the internals, and;
saw some tiny spots on top of piston in both of them
a slight stratch on the side of the piston, and slightly gritty feel on the front bearing in one of them.
these things I have mentioned are very little, but I got nervous.
their production year is 2007.
Can they lead to an issue in future? Im going to use them in nationals this year.
Sorry for bad english...
thanks for the replies.
musti72 is offline
