Like Tree195Likes
Novarossi engines thread
Old 08-21-2007, 09:29 AM
  #2356
CIMRI's Avatar
Originally Posted by stefan
MAX 2602, you are going to be very surprised.
I know I was after I switched from the 2630....
danke für die prompte antwort. Hat diese auspuffanlage auch sein eigeness manifold? Ist es ok
CIMRI is offline
Old 08-21-2007, 09:48 AM
  #2357
Gael L's Avatar
How so? More torque, tope end or both? Do you think the 2602 would also be a good fit for the plus 12?
Gael L is offline
Old 08-21-2007, 11:43 AM
  #2358
cdelong's Avatar
Originally Posted by Corse-R
The engine that applies are a pair of JP Racing B5-T and a Nova Plus 21-7. The break-in is finished (or almost like the 21-7) and need to change the conrod of all two. My question is regarding the conrod type.... Plain R7 or R6 with hardcoated wrist pin?
The JP came with the R5 and the 21-7 came with the R7, but checked dimensions and the R5, R6 and R7 are the same. Only changes small details: R5 is the heavyest, R6 is lighter but comes without the upper bronze bushing (and I think that needs a hardcoated wrist pin - only available thru JP Racing) and the R7... seems to be almost light like the R6 but with upper bronze bushing.
Those are Off-Road engines, they buzz on my truggy...
Salvatori, Uriah, ... ?
I'd stick with the R5 and R7. IF the engines are dynamically balanced, you'd want like for like replacements due to balancing the crank to the weight of the components.
Personally, I'd steer clear of the non-bushed rod.
cdelong is offline
Old 08-21-2007, 12:22 PM
  #2359
stefan's Avatar
This pipe got more of anything, trust me. Yes, I'm also running it on a Plus 13-3ST with great results.
stefan is offline
Old 08-21-2007, 12:23 PM
  #2360
stefan's Avatar
Yep, it got a unique looking conical manifold.
stefan is offline
Old 08-21-2007, 12:49 PM
  #2361
CIMRI's Avatar
thats good. actually Im not happy with the performance of the 353. Hope the pipe will be help.
thnx
CIMRI is offline
Old 08-26-2007, 05:44 AM
  #2362
Default Pipe
thnx
You should consider trying the novarossi pipe. You will be surprised.
Johny is offline
Old 08-26-2007, 10:22 AM
  #2363
Trader Rating: 28 (100%+)
He said he is currently running it with the Nova 2630 pipe and manifold.
Scott Fisher is offline
Old 08-29-2007, 07:04 PM
  #2364
SalvadoriRacing's Avatar
go with the R5 for the JP one...........
you would not achieve better performance with a lighter one, so stick with the most reliable one since you will not gain anything noticable specially racing offroad......
I haven't seem the JP version in person, but I'd only stick with the R7 in the PLUS 21-7 since it's supposed to be reliable even with the light conrod.......
SalvadoriRacing is offline
Old 09-03-2007, 03:26 PM
  #2365
royfan33's Avatar
Guys, need some input here from anyone that has ran both, or ran with either a Nova +12Ct/2630 or a Max Power SL3 combo. I run on smallish track and an engine with a decent bottom to midrange would be nice. Just needing some opinion as I can't find much on the SL3. I do see that the +12 is a longe stroke whereas the SL3 is closer to a square stroke, so I would think the +12 may have a little better bottom end.
FWIW I've been running a Ninja in my NT1 and it can be ballistic, but I've had one too many days of chasing a tune.
thanks
royfan33 is offline
Old 09-04-2007, 03:08 PM
  #2366
JetMD's Avatar
Is this the Mega pipe you are talking about? http://www.serpent.com/product/223015/
Does anyone know where to get these in the US? The only places I can find that sell these are overseas.
JetMD is offline
Old 09-05-2007, 03:13 AM
  #2367
stefan's Avatar
Yes, it's the same than the Max Power 2602 (the Max comes also with the same conical header):
I don't know who imports max engines to the US.
stefan is offline
Old 09-05-2007, 03:15 AM
  #2368
stefan's Avatar
RC America imports Max in the US.:
www.rcamerica.com
stefan is offline
Old 09-05-2007, 03:20 AM
  #2369
stefan's Avatar
www.rcamerica.com
You ought to start using Google
http://www.brooklynhobbies.com/index...OD&ProdID=2077
stefan is offline
Old 09-05-2007, 04:06 AM
  #2370
Pattojnr's Avatar
Trader Rating: 19 (100%+)
hey guys, i have a plus 12-3sct coming soon, any pipe recomendations and run in procedure ? and how is the longetivity or life span of the engine going, reliability ? thanks guys.
Pattojnr is offline
