Like Tree195Likes
Novarossi engines thread
Old 10-05-2006 | 06:35 PM
  #1726
rudeboy's Avatar
Hi guys need to know. If I could run a (stock).
Novarossi on 30% with out shiming the head.
rudeboy is offline
Old 10-05-2006 | 06:39 PM
  #1727
mugenb46's Avatar
they are shimed already, but i have always ran 30 without adding a shim and had no problems, it uselly will help prolong the life of the motor and help reduce temps. i would get a second appinion though.
mugenb46 is offline
Old 10-05-2006 | 06:45 PM
  #1728
rudeboy's Avatar
Thumbs up
Thanks alot mugenb46
rudeboy is offline
Old 10-05-2006 | 06:47 PM
  #1729
mugenb46's Avatar
what motor do you have?
mugenb46 is offline
Old 10-05-2006 | 06:55 PM
  #1730
rudeboy's Avatar
Rs12s2
rudeboy is offline
Old 10-05-2006 | 07:09 PM
  #1731
mugenb46's Avatar
ya i would run it stock shimming. but if you want to ad shims start off with one or two .001 shims.just keep an eye on the piston dome. if you see pitting or it starts to look pitted then add a shim or two. this is what detanating is. you can also check your deck hight and post it on here and someone can tell you if your close or not, but i think you will be fine with 30 and stock shimming. good luck,have fun
mugenb46 is offline
Old 10-10-2006 | 01:02 AM
  #1732
antoine80's Avatar
Default broken LL5
hey all..
this is what happend to my engine last saturday
any idea? should i go for a new engine? has anyone suffer the same damage?
br
antony
antoine80 is offline
Old 10-10-2006 | 01:46 AM
  #1733
asw7576's Avatar
Originally Posted by antoine80
hey all..
br
antony
Damm......
I think the crankshaft is bent, and thus vibrate.
Need to replace the front and inside bearing.
I suggest to buy new engine because the cost to rebuild probably is half the price of new engine.
asw7576 is offline
Old 10-10-2006 | 01:54 AM
  #1734
antoine80's Avatar
Originally Posted by asw7576
Damm......
some weeks ago i replaced the inner ball bearing.. it was destroyed, i also think that the crankshaft has been destroyed that time and now just broke.. but the bearing at least the inner one seem to be good.. also i am lucky enough and pieces of the broken iron didn't scratch the piston the main problem is that even if i change the crankshaft i am not sure if the engine will work ok. i have run about 6ltrs of fuel. how often should someone change the rod?
Old 10-10-2006 | 02:08 AM
  #1735
asw7576's Avatar
I suggest buy new engine.
Change conrod every 2 gallons and/or everytime you replace p/s/r
Next time when you put the flywheel, always use proper tools. You tighten the flywheel locknut hard enough but not too hard. Use oil lubricants to collette, flywheel, and flywheel locknut's threads. The lubricants aid the tightening process. It won't slip during use, trust me !!
asw7576 is offline
Old 10-10-2006 | 02:14 AM
  #1736
antoine80's Avatar
what do you mean p/s/r ?
can you explain me a bit more what you mean about locking the flywheel? i should use some oil while tightening the flywheel nut?
Old 10-10-2006 | 02:22 AM
  #1737
SalvadoriRacing's Avatar
p/s/r = piston, sleeve and rod
regarding the bearing change, you may installed the bearing with bad alignment with the front bearing, causing some bind on the shaft.....
there's a tool to install bearing properly aligned with each other.......try to get one of find a hobby shop to make this service for you next time......
SalvadoriRacing is offline
Old 10-10-2006 | 02:26 AM
  #1738
antoine80's Avatar
ok this is a problem, i didn't know this i though that the bearing just sits inside the engine and the alignment is correct because the bearing "case" was tight.. i suppose this was wrong
Old 10-10-2006 | 06:46 AM
  #1739
EdwardN's Avatar
Exclamation Novarossi main bearing
Just to mention to anybody who wants to change main bearing on Novarossi based motors-be carefull, Novarossi main bearings made offset and proper direction is required. Shorter side goes to back side of motor.
It is just tip to follow.
EdwardN is offline
Old 10-10-2006 | 06:55 AM
  #1740
antoine80's Avatar
this is something new to learn although i have changed my main bearing i didn't know this.. when you say shorter side you mean for the inner "circle" of the bearing or the outside?
