Like Tree195Likes
Novarossi engines thread
Old 09-26-2006 | 10:15 PM
  #1681
Originally Posted by Team Kamikaze
Maxy modified Plus 12-3CT SAN PIE PA SHAE OOH
is the plus series the latest from novarossi?
ickvanovs is offline
Old 09-26-2006 | 11:32 PM
  #1682
Chris West's Avatar
yes it is
Chris West is offline
Old 09-27-2006 | 01:23 AM
  #1683
asw7576's Avatar
What engine do you use now ?
Looks okay to me the last last time we met.
The plus series are definetely faster at top speed.
asw7576 is offline
Old 09-27-2006 | 05:25 AM
  #1684
at the moment im using LL5, i bought it 2nd hand tho...
thinking to order a new engine for next year race season. so yeah, im doing some research about engine.
any recommendation?
Old 09-27-2006 | 09:16 AM
  #1685
suntok2's Avatar
any recommendation?
Go with Nova Plus 12-5ct
suntok2 is offline
Old 09-27-2006 | 09:35 AM
  #1686
mtveten's Avatar
MOSMO is the way to go, its the best of the moded novas.
Mark
mtveten is offline
Old 09-27-2006 | 10:42 AM
  #1687
afm's Avatar
afm
Mark
You mean MasMo = Massimo Fantini Modified = Novamax = Max Power Engines
AFM
afm is offline
Old 09-27-2006 | 11:08 AM
  #1688
mtveten's Avatar
yep the Fantini job is my favorite. I prefer the 3 needle carb and for some reason its just a bit faster than my tuned nova and shows less wear after twice as much use.
mtveten is offline
Old 09-27-2006 | 11:26 AM
  #1689
EEChris's Avatar
Do anybody know how many additional head shims are needed for the 12+3ct?
EEChris is offline
Old 09-27-2006 | 01:02 PM
  #1690
AFM
Yes M. Fantini mod is good, but very pricey and rare.
silverM3 is offline
Old 09-27-2006 | 01:10 PM
  #1691
i have the plus 21-3c i hope it will run good next season
is it possible to buy new heads?
Orfeous is offline
Old 09-27-2006 | 02:34 PM
  #1692
afm's Avatar
afm
depends on what % of nitro you are using
AFM
afm is offline
Old 09-27-2006 | 04:23 PM
  #1693
Grinder's Avatar
You do not need any more head shims to run 16-20%. If you want to run 30% you should add at least one .1mm head shim. You may want to add a total of .2mm depending on the weather, and powerband wanted. This is a total of .4-.5mm of total head shims. This should get you close.
Grinder is offline
Old 09-27-2006 | 05:39 PM
  #1694
I am new to 1/8th and I have something that I have been wondering about and would like to know what you guys think about the subject.
My first and only race with the car on the first qualifier the car was stock with mid to large size tires ( not sure the exact size) and I just made time, came across the line and ran out of fuel.
After that run I put a one tooth smaller spur on second gear because I thought that the car was topping out early on the straight. The car ran out of fuel even earlier. I also put a little more wing in the car so I think that I was getting in the throttle a little bit harder and earlier then in the first qualifier.
For the third round I thought that the tires where getting small so I put the stock spur back on and put a one tooth larger pinion on second and it ran out of fuel even sooner then the other two rounds. I don't know what the over all roll-out was to really be sure.
Is it possible that the engine is more efficient geared higher like in the first round? I do know that I had a faster qualifing time each round untill I would run out of fuel on the last two rounds.
THE DOCTOR is offline
Old 09-27-2006 | 07:27 PM
  #1695
OVA's Avatar
OVA
Mark
Okay Mark don't get carry away Not everybody can pay the price
OVA is offline
