Like Tree195Likes
Novarossi engines thread
Old 08-08-2006 | 06:00 PM
  #1591
SalvadoriRacing's Avatar
a pinched piston/sleeve set is not like a brand new............it can be sooooooooo tight, just depends how it's done........
and when you manage to turn the engine it looses its pinch within few tanks...........
don't worry, a new engine won't be that hard to start........
SalvadoriRacing is offline
Old 08-08-2006 | 07:42 PM
  #1592
gearhead13's Avatar
I actually managed to run about 8 tanks through it, and it was still getting stuck at tdc.
Good to hear i wont be going through THAT again with my new engine
gearhead13 is offline
Old 08-09-2006 | 12:52 AM
  #1593
ziggy12345's Avatar
Its been cripped to much... Its now a paper weight
ziggy12345 is offline
Old 08-09-2006 | 10:06 AM
  #1594
Anyone ever have to refill there filled rex/novarossi crank for any reason? if so, what did you use?
Thanks,
-AL-
ALJR is offline
Old 08-16-2006 | 06:16 AM
  #1595
suntok2's Avatar
Default Plus 12 -5CT
Hi guys I will test this new engine and let you know about its performance
suntok2 is offline
Old 08-16-2006 | 09:32 AM
  #1596
FF25510's Avatar
[QUOTE
Hi guys I will test this new engine and let you know about its performance[/QUOTE]
i'm interested in this engine too, wait for your test report !!
FF25510 is offline
Old 08-17-2006 | 09:38 AM
  #1597
spenzalii's Avatar
I can attest to these statements. My NSR12S5 sleeve gave out during a race once. Had it pinched, and within 3 races, it was back to where it was originally. So I ordered a new set.
If you break it in correctly, it shouldn't have a problem running it, but it will take some time to get that first tank thru. The P/S set for the NSR was so tight it would not turn over with my box. It was so bad the starter box belt actually stripped. After replacing the belt and getting a heat gun, I got it to turn. My RB was even worse. For the first 8 tanks, I still needed a screwdriver to unstick the flywheel.
spenzalii is offline
Old 08-17-2006 | 11:11 AM
  #1598
Osiris 75's Avatar
Well, I was told not to use the screwdriver technique, because it can scratch the piston or something. It was recommended to just use the heat gun, but eventually I had to use the screwdriver because the flywheel would not budge!!
Osiris 75 is offline
Old 08-17-2006 | 07:30 PM
  #1599
wallyedmonds's Avatar
i think we all have had to do this lol hmm
wallyedmonds is offline
Old 08-19-2006 | 12:11 PM
  #1600
a friend have a used PLUS 21-3C for sale.. he told me that he is replacing the conrod? (unsure the name of part) to a new one before i buy it. should i buy it?
now i have an old mega sx21-ev1
or should i go for a new mega zx ds2? (powerpack) for near the same price.
2500SEK for the nova and 3500SEK for the zx21-ds2
Orfeous is offline
Old 08-19-2006 | 12:29 PM
  #1601
nigelnuggets's Avatar
Orfeus,
I will go with the new DS II it will be much better.
nigelnuggets is offline
Old 08-19-2006 | 12:34 PM
  #1602
Ok, hmm... i really like the nova.. but.. mega zx21-ds2 runs very good.
he will include 3 chamber pipe and a exhaust
Orfeous is offline
Old 08-19-2006 | 12:40 PM
  #1603
Corse-R's Avatar
I have a small tip for all those who need to untrap the piston. Grab an allen wrench (please, not a ball shaped a straight one) and if your piston gets stuck, chuck the allen key into the screw that support the axial bearing and do a CW movement (engine runs in CCW) so you can untrap the piston easily without marring the flywheel.
Corse-R is offline
Old 08-19-2006 | 12:56 PM
  #1604
i have made my decision.. i'll go for the nova.. it will be very good.
Orfeous is offline
Old 08-20-2006 | 06:36 AM
  #1605
suntok2's Avatar
We tested the engine and its really fast So we have to change set up again just to drive this engine
suntok2 is offline
