STS engines
#2701
Yes, I ran one last two seasons. The bigger gear combo and an RD Logics Turbo II pipe made this engine a strong performer in the infield. The straight away performance is good for medium sized tracks, but you won't maintain pace with the high performance engines. The engine was very reliable and didn't require a lot of tuning time.
#2702
STS12X3
we will be adding more videos of our engines soon!!
STS12X3 and G4Rs 2009
Notice that our engine was running very rich, we will have more videos of the engine tuned leaner for even faster speeds.
+ YouTube Video | |
#2703
Trader Rating: 26 (100%+)
few more tanks on the sts12x3. i will post just how fast this bad boy is
thank Machinaria for the great deal
#2704
#2705
Black Friday!!!!
1
#2706
has anyone tryed to mod. the 12x3 on their own to get
alittle more out of it
#2710
S12X3
Andrew, not sure yet I just ordered one to try out after my OS Speed 12tz blew the rear bearings on it.
So had to use my spare D5 (not the D5R) i had from 7 years ago, I can say that from the quick tune it was good in race conditions on our small track. I did manage to get fastest lap in a heat and very comparable with lap times to the 12tz. It also managed to get runtime of over 6 minutes which I couldn't get on the 12tz.
So I'm hoping that the S12X3 has more power bottom to top, to keep up with the TZ SpecII's.
On the D5 i used an OS P7, but it has keeps leaking at temperature, so switched to a Odonnel 97T. I think I'll give that a go on the S12X3.
Not sure when I can break it in and if I'll be able to race it before sometime in October to give you some feedback.
Depending on the price I would just get it to try out.
Anyone else able to provide feedback on the power of the S12X3 compared to an OS and what runtime they are getting?
#2711
i made the cuts on the sleeve alittle deeper
and it's FAST!!! try it with a novarossi or maxpower
pipe. guys that run all them big money engines
are like WOOOOW!!!!! 2 gal. in the one and still fast
#2712
Hi Randy,
Which pipe would be good from max power or nova rossi for a tight small track with one long straight? It would also need to make 6 minute heats without pitting.
You wouldn't have photos of the sleeve you modifiied, would be interesting to see.
I've got mine and cleaned her up and sealed her up again, waiting to break her in. I'll use the S12 for the summer series comming in a few months.
Jason.
Jason.
#2713
Hi Randy,
Jason.
Jason.
and for the pipe try the maxpower 2602 i get almost 6min and 15sec.
#2714
ok who has the new L12X3 and how is it
#2715
I don't think the L12X3 is newer than the S12X3. Product no is 1205 for L12 and the S12's are 1211 and 1212.
The internals look similar to the D12X when you compare product no's on the parts list, i just couldn't match the p/s set the crank is the same.
I have seen it cheaper in some stores and a little more expensive in other's when compared to the S12.
thanks
Jason.
thanks
Jason.
