STS engines
#2582
#2584
#2585
I have All new sts engine will coming soon at end of this month(comfirm),STS s12x3 already try at last month competition,very smooth & powerful & easy tune engine,anyone interest please call or sms or pm me about the price (limit Stock only) (012-809-2626 John Hii)
Will arrive
1) S12X3 Ifmar legal .12 engine (TEAM)
2) S21T Buggy Engine (TEAM)
3) S21R 1/8 Onroad engine (TEAM)
Here is the link http://www.stsrc.com.tw/
PS:i come from malaysia
Will arrive
#2586
Registered User
Most STS Engines IN STOCK
We also carry most all STS Engines in STOCK, if the engine you want is in stock, we will have it shipped in 3-5 days. You can check us out at the link below, we are adding more products everyday!! Thanks!
www.nitrocountryRC.com
WE ARE IN THE USA
WE ARE IN THE USA
#2587
Well it finally happened, I have a broken sts 30... Ive been lucky so far, this is my fourth sts 30 that I was keeping as a spare.. I took sometime to break it in (been sitting in a box for a while now) and could not get it tuned right, switched carbs on it and everything. Even with a novarossi carb on the motor it still ran like poop, stripped it down and found the answer. A slight crack in the block in the upper left hand corner of were the motors back plate screws into.
So i guess the question is "will dino replace this block or am I out of luck since Racer9 stopped carrying these motors."
#2588
hi there, is changing to novarossi carb really make sts engine better? cause i got a .12 touring engine.... always got tuning problem....suspect is the carb problem...as the internal of the engine is fine and this engine is only 2L old. so also got think of changing to novarossi carb as it fit sts engine! So would like to know if it does makes any changes before i buy a new carb! lolx! Thanks!
#2589
Yes the NR carbs help alot, the sts carbs are very inconsistent in build quality. Also if you want to teflon the LSN of the sts carb, that in its self is a big help.
#2591
Check your PM!
#2594
Hi guys,
From what i know, STS is a Novarossi Base engine. Where Novarossi engine is a high rev engine, which mean STS engine is also high rev engine??? But i read some thread it say that STS have a lot of torque! So i thinking of which gearing to use? lolxxxx!
#2595
use yr good hearing!
use a gearing that yr engine peaking at the end of the straights.
