maxpower engines ?
Old 02-01-2008 | 09:31 AM
  #16
ma racer's Avatar
Will do. It might be a little while though seeing as how the current cost of a P/S/R/H is up there. around 360 USD.
ma racer is offline
Old 02-02-2008 | 12:01 PM
  #17
Originally Posted by captian
21-35. stock and the max xrs head shims set up
Hi Captain,
I also have a Max Power XRS-21.
If I'm understanding you correctly, the stock P/S/R/H for the 35 Plus 21 will fit in my XRS-21 case.
The Novarossi part # I found for the 35 Plus 21 P/S/R/H set is # 08551.
Is this what you are using in your Max XRS case? If so I will get one as soon as possible for a rebuild.
thanks
Kendall is offline
Old 02-03-2008 | 05:33 AM
  #18
Originally Posted by Kendall
Hi Captain,
thanks
i've recently purchased some max and novarossi parts for my MAX. althought they are the same engine, and the same part numbers the max parts are infact sometimes different. ie the conrod for the .12 max is different to the conrod for the .12 nova, also the nova c clips packet (i believe from memory) comes with more clips (4 in total) than the max which comes with only two per pack. again part numbers are the same as nova, but different. weird.
TomB is offline
Old 02-03-2008 | 03:48 PM
  #19
captian's Avatar
Hi Captain,
thanks
i will check but i believe thats it !!!! but you can all so use the 21-3 set up too
captian is offline
Old 02-12-2008 | 02:28 PM
  #20
deviltires's Avatar
anyone know if there is any other piston and sleeve that will fit in a mf .12 and head button
deviltires is offline
Old 02-13-2008 | 05:14 AM
  #21
the novarossi 12sct piston liners i believe are the same.
tell me if you find a place that sells the max head buttons for the SL3 as i have not been able to find any, either here in Oz with the distributor or overseas.
TomB is offline
Old 02-16-2008 | 04:02 PM
  #22
tony montana's Avatar
thats what i dont get, sell a awesome engine and dont have parts anywhere to be found.
tony montana is offline
Old 02-17-2008 | 02:27 PM
  #23
CIMRI's Avatar
There is 2 version of max 2602 pipe on the market. The EC and TC version. Does anyone know what is the difference. I want use on my 353 nova. Many people wrote the 2602 combination is the best for 353.
thnx
CIMRI is offline
Old 02-18-2008 | 02:55 AM
  #24
i recently started breaking in my max LS2 MF today with runnertime 16% i found this strange light brown splatter ont he top of the piston, and on the exit of the exhaust port, any one else found this? performance is fine, and most of it wiped of but it seems like it got baked on.
is it possible that the machining oil from factory did this?
TomB is offline
Old 02-18-2008 | 03:04 AM
  #25
Roelof's Avatar
Like this ?
That is normal, it shows a good combustion and most of the time the brown layer is caused by castor oil.
Roelof is offline
Old 02-18-2008 | 06:21 AM
  #26
no nothing like that, it looked alot like a splatter effect.
it looked like rust particles on the top of the piston but it wasn't rust. it's hard to explain, and i cleaned most of it of, but it seems like an oil that burnt on the top of the piston, or some sort of gluey substance. it is still on the inside of the outlet of the exhaust port on the walls.
it is a medium brown colour so it isn't burnt on, and seems to have dried on at a low temp.
i've never seen it before. i'm putting it down to oil residue left during the construction that might have been in the bearings possibly. i'll see if i can get a pic of the remaining bits of the "stains"
TomB is offline
Old 02-19-2008 | 04:52 PM
  #27
PROVK's Avatar
Tom
I found that when I was using runnertime it would leave a lot more stains like that and even gunk in the bearings when left unsed for a few weeks.
Ruunertime has a lot of caster oil in it.
PROVK is offline
Old 02-20-2008 | 04:54 AM
  #28
Originally Posted by PROVK
Tom
hmm possibly it's never happened to me before. i wiped as much of as i could and it seems to have come of the top of the piston now that i have run it at close to race temp.
TomB is offline
Old 02-23-2008 | 10:13 AM
  #29
Default pipe and manifold
hi, I've recently bought a new 2602 EFRA pipe, but it couldn't fit into my old MAX manifold that I've been using for years. Pls advice... Thanks
backplate is offline
Old 02-23-2008 | 02:54 PM
  #30
Team Kamikaze's Avatar
The new Max manifold end is bigger, you will have to buy the new manifold inorder to use the new 2602 pipe.
Team Kamikaze is offline
