Reassembling an engine.
Old 07-03-2007 | 04:15 PM
LogiK's Avatar
Default Reassembling an engine.
Hi,
I Was told when reassembling an engine to use after run or some fuel to coat it to make it easier and easier to burn the crap you cleaned it with..
Is this true or what should I use?
Thanks.
LogiK is offline
Old 07-03-2007 | 04:21 PM
rmdhawaii's Avatar
Use after run oil. When you clean the engine, you remove all the lubricants. Coating the parts prevents you from turning over a "dry" engine, which is a very bad idea.
rmdhawaii is offline
Old 07-03-2007 | 04:46 PM
va_connoisseur's Avatar
Is this also true for a new engine? Should I break it down and clean the inside, as well as coat it with after-run oil before ever installing it in the car?
va_connoisseur is offline
Old 07-03-2007 | 05:18 PM
LogiK's Avatar
Now I cant get the sleeve back into the crankcase .
LogiK is offline
Old 07-03-2007 | 05:21 PM
rmdhawaii's Avatar
Some people recommend taking the engine apart to inspect it for any debris leftover from the manufacturing process. It also gives you the opporunity to inspect tolerances, see how much play everything has and what all the surfaces look like (take a photo if you can). That's good for "before" and "after" type comparisons - especially if you encounter any major problems with the engine - like overheating, essessive wear, bearing failure, really bad front bearing leakage, etc, etc.
It's always a good idea to take your engines apart and inspect them on a regular basis. The more you get use to what the insides of your engines are suppose to look like, the better you'll know when there is some issue that you need to address.
Old 07-03-2007 | 05:22 PM
rmdhawaii's Avatar
What engine??
Old 07-03-2007 | 05:28 PM
LogiK's Avatar
TRX 3.3 from my revo.
LogiK is offline
Old 07-03-2007 | 05:43 PM
rmdhawaii's Avatar
I've never worked on that engine before, so I'm reluctant to give you any advice. There is some info here:
http://www.traxxas.com/support/index...on=show&cat=35
... and if that doesn't help, you can call customer support at 1-888-TRAXXAS
Old 07-03-2007 | 06:08 PM
doki_doki's Avatar
From: Cebu City, Philippines and Ocala, Florida, USA
Well, before I didn't bother to clean my brand new engines before breaking it in. Most of the engines that I have used were the OS ones. When I started using the Nova engines, a friend of mine recommended that I take the engine apart and clean it. That is what I did and to my surprise it had some minute debris in it. I'm sure glad I took it apart and cleaned it. Also, I put a few drops of after run oil in the engine everytime I take the engine apart. This is to keep the engine internals oiled before breaking it in or running it again. It sure helps to keep the internals well lubricated as to running it dry...
doki_doki is offline
