JL Racing .12
#331
Hi, i beleive the LRP Z12R TEAM SPEC3 has the same power/performance of JL RED DOTs , I would like to know if am I right ?I think same internals execpt the red filled dot on crankshaft, I use the LRP spec 3 so if i am right, with sure the JL Red Dot its a awesome engine too , i saw very good results with Red Dot on USA .
#332
I've just got one of these engines but I'm having trouble getting the flywheel nut to crank down, the crankshaft is turning along with the nut and its still slack enough that the flywheel will turn independently when the piston is at the top of the sleeve.
Any tips?
Any tips?
#333
Any tips?
Any tips?
#334
I've managed to get it on now but ended up using a different collet.
#336
Originally Posted by Neesh
does anyone know if there is some ceramic bearings for this motor? anyone know the size of the front and rear?
it includes:
12 X 21 X 5mm rear inside bearing MR6801C-TH9-C3
6 X16 X 5mm front bearing SMR616C-2YS-NB2
AFM
#337
I tested ceramics is one of my motors and did not find it any better.
#338
#340
Originally Posted by rmdhawaii
Perhaps a set of Murnan ceramics would show a more noticeable improvement - but I don't think he makes a set for the Red Dot.
no difference at all? so why all the hype on ceramics on the newer BIG dollar motors?
#342
thanks guys for the replies.
RMD who are you? are you racing this sunday?
#343
Within what temp range does the Red Dot like to run? Does it like a rich bottom end setting?
#345
Originally Posted by Team Kamikaze
Not too rich where it struggles to accelerate. just rich enough for it to puff a good amount of smoke when you accelerate from a dead stop.
