Like Tree1Likes
JL Racing .12
Old 07-20-2008, 09:56 AM
  #1621
gentleman81's Avatar
from CA to VA, help at anytime!!!
gentleman81 is offline
Old 07-22-2008, 12:12 AM
  #1622
Trader Rating: 55 (100%+)
Ordered my JL3 from the folks at Kamikaze last Monday and it showed up on Wednesday... thanks for the great service! It started right up and I went through the first 3-4 break-in tanks as easy as could be. After sitting for a day, I'm now having some trouble getting a consistent idle. So, a couple of questions (running with a VR12+ pipe):
1. The Picco plugs weren't available at the time, so I'm using OS P6, which is a hot plug. Will I have trouble hitting a good idle with a hot plug?
2. I noticed that the factory settings for the LSN seem to be a couple of turns out from flush, which would be about 5 turns out from full closed. If I try to use the baseline 3 turns out from closed, it seems way too lean on the bottom. Anybody else have their LSN above flush?
Thanks for the help.
WatchOut is offline
Old 07-22-2008, 02:06 AM
  #1623
it should idle fine fine with that plug and yes my LSN is above flush
cdub is offline
Old 07-22-2008, 07:14 AM
  #1624
Team Kamikaze's Avatar
Just keep in mind that as the engine breaks in, it tends to run richer, so just lean out the LSN 2 to 3 hours from originally where it was and it should idle fine (4 1/2 to 4 3/4 out from close) and if you can use only PICCO P6TH glow plugs for more consistent tuning.
Team Kamikaze is offline
Old 07-22-2008, 11:26 AM
  #1625
I need to start breaking my new Red Dot in. And use the old one as a back up.
My LSN has about 2 1/2 threads showing on the screw. And the HSN is just a hair above the stem. Had to back richen the LSN to get it to run cooler in the heat/ humidity. It still screams and blows smoke. Also comes back with a 1/4" of fuel in the tank. Thats good for 301 Raceway.
SRW141 is offline
Old 07-23-2008, 05:43 PM
  #1626
Mugenville's Avatar
Trader Rating: 25 (100%+)
Sam, my engine and other goodies arrived this morning , if you happen to find an empty picco box laying around that would be mine , Very happy with the after sales service that you give and all your help, pity you don't live on the Big Island
Cheer's Rob
Mugenville is offline
Old 07-23-2008, 06:02 PM
  #1627
Cheer's Rob
I have a lot of empty engine boxes laying around in the shop, and I am sure one of theses is yours, I'm sorry I forgot to send back your engine box with the engine, I will send it back to you on your future order.
I though you broke it in already.
  #1628
yes, the service is great. let me know when you wanna start a Team Kamikaze II in VA VA!
Old 07-23-2008, 06:08 PM
  #1629
I will and you will be the first one to be notified
Old 07-24-2008, 09:34 AM
  #1630
Haven't had a chance yet. Next week. Not racing for two weekends. Paintball tournamounts with my son.
SRW141 is offline
Old 07-24-2008, 01:30 PM
  #1631
Uga
Uga's Avatar
I lost one of the wrist pin retainers while changing the rod (you probably know, how easy it is to loose them ). I don't have any spare.. Will retainers from Orion CRF fit to the Red Dot? Also I could get some from offroad 3,5 cc engines, if they would fit..
Uga is offline
Old 07-24-2008, 02:08 PM
  #1632
You can try using a different brand, but make sure the thickness of the retainer clip is identical, so it would seat perfectly on the groove within the piston, that way it will be more secure and will have less chance for the clip popping out.
Old 07-24-2008, 02:31 PM
  #1633
wingracer's Avatar
Trader Rating: 24 (100%+)
I always get wrist pin clips with a rod. Not because I lose them but because I do not like to re-use them.
wingracer is offline
Old 07-24-2008, 02:37 PM
  #1634
Good point! Wrist pin clips are a actually a very cheap insurance.
Old 07-24-2008, 02:51 PM
  #1635
do u have them?
