Like Tree4Likes
  • 1 Post By Roelof
  • 1 Post By 1/8 IC Fan
  • 2 Post By Roelof
O.S.SPEED R21 EURO II
Old 05-11-2022 | 10:16 AM
Default O.S.SPEED R21 EURO II
osspeed.com/eng/2022/euro2_e.html
Euro Spec 2
madjack is offline
Old 05-12-2022 | 05:36 PM
1/8 IC Fan's Avatar
  • Displacement: 3.49 cc / 0.213cu.in.
  • Bore: 16.08mm / 0.633 in.
  • Stroke: 17.20mm / 0.677 in.
  • Output:2.8 ps / 2.76 hp / 35,000 r.p.m.
  • practical rpm range: 4,000-45,000 r.p.m.
  • weight:340g / 11.99 oz.
  • Standard accessories
  • Glow plug RP7
  • Exhaust seal ring Dust cap set (φ3、φ16、φ18)
fixed it for you.
1/8 IC Fan is offline
Old 05-12-2022 | 11:11 PM
Roelof's Avatar
The cooling holes under the exhaust, 3 weight inserts and even a groove in the upper lip of the sleeve. I would say Novarossi is copied very well.....
1/8 IC Fan likes this.
Roelof is offline
Old 05-13-2022 | 03:49 AM
1/8 IC Fan's Avatar
Roelof, I guess now that the old Nova is no more, and as such I am not sure who now has the rights to patent / design / copyright etc. I am sure they will try more of the Novarossi "black magic" lol
VS_Rody likes this.
Old 05-21-2024 | 09:42 AM
Hi Roelof, may I know whats the difference between 3 weights vs 2 weights on the crankshaft?
tq23 is offline
Old 05-21-2024 | 12:25 PM
Roelof's Avatar
To give you a reason to buy the new one with the 3 weights because the older with 2 weight is not fast anymore.
The weights are basically for balancing, maybe in the hands of a very good driver he can notice the difference, for the most there is no difference. On paper it is even a bad idea because it is more rotating mass
TC3MIKE and VS_Rody like this.
Roelof is offline
Old 05-21-2024 | 05:11 PM
TC3MIKE's Avatar
If I wasn't going get another Shimo II, the Euro Spec II would have been my choice just because of the crankshaft.
TC3MIKE is offline
Old 07-04-2025 | 06:08 AM
990driver's Avatar
Just purchased a euro 2 from Rcxx the website/store is in Switzerland-I purchased the last one and it was on sale for 50%off at 268+37 dollars shipping and it all came out to 305 bucks that’s a great deal in my book any way you slice it…I’m just debating if I want to send it do Rick brake or Uriah murnan for a drag mod like I do to 90%of my engines since I run a lot of 132ft drag racing…if anyone has any experience with the euro 2 chime in and let me know what you think..I hope the break in goes smooth with no scored piston..but with it being 7 port and having the 2 lubrication holes u see the exhaust port I hope it’s easier on the piston for break in
990driver is offline
Old 07-05-2025 | 04:52 AM
990driver's Avatar
What’s the best pipe set up for this motor for top end…is it just the 2098 with the short header or has anyone noticed anything better than the above set up
Old 02-01-2026 | 03:55 AM
invrtd's Avatar
If you can find a 2052 pipe. It's a beast on top end. It's a nova pipe though. It's a gas hog for onroad so for drag probably wouldn't bother you. I have a used spare sitting on the shelf if interested.
To keep on topic, any point in upgrading from 2103 or Euro 1 to Euro 2? If the crank weights are the only major change, I think I will just rebuild my older engines.
Heading to winter Nats tomorrow for some great racing! Hope it warms up a bit! Not used to freezing weather in Florida.
invrtd is offline
