Rody Victosport VSB01 - OS XZ-B based
#16
So, while we understand you are ranting here a bit, I hope you do understand that Rody does do a lot of engine work and development. Not to mention that he does hold a world championship title, from a time when engines were a lot less reliable.
Do you feel that same way towards Novarossi? They are not applying DLC to their crankshaft?
And please too be considerate in that Rody's native language is not English, as such the translation and wording as stated should be taken into consideration, and perhaps he meant to say that by less direct on the throttle is perhaps less snap and responsive-ness to iniatial servo input.
#17
Thanks 1/8 IC Fan for helping me out.
Indeed English is not my native language and so sometimes an extra explanation is needed.
DLC stands for "Diamond Like Coating" and this is a very thin layer of very hard coating applied on a already hardened surface.
These treatments are generally applied on machine tooling like carbide cutters, drills etc. This to increase the life and cutting chips not getting stuck.
Depending on the type of DLC coating(yes there is more then one) a certain temperature(heat treatment) is needed to apply this coating.
Since the crankshaft has already been heat-treated before in general the crankshaft becomes a little softer and so more flex on the shaft itself appears and can be of influence on the performances.
Before DLC treatment was released I tried the TIN surface coating(gold colored finish) but after we applied this coating, the crankshafts were like there was no more heat-treatment and there was a real big difference between.
First I tested the engine on the track with the normal crankshaft and the throttle response and power was very good.
Then we changed the crankshaft to the one with the TIN treatment and the engine had the same top-speed rpm, however it took more time to get to this rpm and also the engine felt soft on the throttle.
When we tested the DLC treatment in the same way, the difference was very less because the crankshaft did not go too soft but was still a little softer despite the low temperatures needed to apply the DLC coating.
These test were made several years ago and in the meantime the quality of the treatments are increasing, so the difference will be less and less.
With this said, before we started to apply the DLC coatings, we had very little problems with the wear of the big-end of the crankshaft, however wear always occurs but I think in the case of our VSB01 engine where I choose not to apply the DLC coating is not only marketing but also a choice of the costs.
Since we are running small productions costs of the different type of crankshaft and design are already more expensive and so I decided not to apply the DLC coating here.
Once we have sold the first batch then I hope to be able to release some other models which will have the DLC coating included.
#18
Hi Guys,
Just want to let you know that the VS Racing engines are now also available at AMAIN
If you have any questions, do not hesitate to contact me.
#20
#22
So for now we stick to what we have.
#23
Rody are your pipes similar in performance to the o.s. 2090 and 2060 pipes?
#25
#26
No problem, haven't had the possibility to test these with our engines, however if Mielke has not changed his way of manufacturing I can say that their pipes are very strong but also rigid, may be a little too rigid in my opinion to get a good resonance. However this does not mean that they do not work with our engines, just haven't tried these...:-)
#27
So, for an off road buggy, which pipe and engine combo should we choose?
#28
The VSB01/EFRA 2135 combo can be found here: http://www.worldchampionproducts.com...5-c-vsb01.html
or on the Amain website: https://www.amainhobbies.com/search?fb=2269&t=2&lg=fb
The pipe under part# VSR-302135L50HD
The engine under part# VSR-VSB01
#29
hi rody could you tell us a bit more about your onroad engine and how it differs
from the O.S. r2102 maybe opening a thread in the onroad section would be a good idea.
thanks rick...
thanks rick...
#30
Here we go, started the thread for you, and Rody, I hope you can add some info to the thread as well.
- being on road biased I have to admit I am pretty excited for the new mills.
