Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Engine break-in inside garage question? >
Old 02-14-2013 | 05:42 PM
Default Engine break-in inside garage question?
Ok this may turn out to be a very dumb question. I have a couple of engines I would like to break-in this weekend on my break-in bench inside my garage. I'm doing this because of very low temps outside. Has anyone done this and what did you do about the smoke. Is there anyway to rig up a piece of hose to pipe exhaust and run it out a window. This would cause a back pressure issue wouldn't it. Need some input and your thoughts.
Thanks,
Worm
"WormGrunter" is offline
Old 02-14-2013 | 05:48 PM
curacing2's Avatar
You're fine doing the hose out the window, just use a hose with the ID larger than your pipes stinger.
curacing2 is offline
Old 02-14-2013 | 06:24 PM
That's good news. I was hoping that was the case. I really appreciate your input.
Old 02-14-2013 | 06:46 PM
j_blaze14's Avatar
fan works, bench lower to the ground, fan perpendicular out the door. shop vac maybe, prop up hose.
j_blaze14 is offline
Old 02-14-2013 | 07:35 PM
sschultz's Avatar
My garage wreaks of nitro! And I love it!
sschultz is offline
Old 02-14-2013 | 07:44 PM
houston's Avatar
nice
houston is offline
Old 02-14-2013 | 10:11 PM
my garage wreaks too but it aint nitrosneaky:
dooug1960 is offline
Old 02-14-2013 | 10:27 PM
coneman's Avatar
would it b those beans u had last night.
coneman is offline
Old 02-15-2013 | 05:01 AM
LOL. Yea that nitro is tuff to deal with. That would definately need a hose out the window.
Old 02-15-2013 | 05:02 AM
What header do you feller's use to get your pipe headed in the right direction. How did you rig yours up. I bought my stand used and it didn't come with a header that's beni with the right angle.
Old 02-15-2013 | 08:31 AM
Limywidget's Avatar
some ear plugs/muffs would be ideal too....if you wanna hear stuff later.
Limywidget is offline
