AEG21 Race - $59
Old 03-28-2014, 06:37 AM
  #196
Jaz240's Avatar
Trader Rating: 52 (100%+)
Originally Posted by easyryder
I think they are fine, DLC coating= Diamond- Like- Coating. I love good cheap shit, that why HK is doing well, Good, cheap, shit that works!!
Your just a funky toe cheap racer with clapped out junk.
Jaz240 is offline
Old 03-28-2014, 06:52 AM
  #197
easyryder's Avatar
True, my car is well over a year old and raced every weekend, its got a little slop, lol
easyryder is offline
Old 03-28-2014, 11:47 AM
  #198
wmazz's Avatar
Originally Posted by hookem34
Quite possibly the best practice engine ever.
Nice and punchy down low but does lack on the top.
Save your big boy engines for race day and put a Trackstar .21 in your
practice rig.
Power is plentiful and crisp. I got 12min. on only the 5th tank, 7.0 carb restrictor with werks 2013
and os p3 plug. I would race this bitch with the best of them, so far Best engine I have
ever had!!
Have you guys tried tightening the squish, or increasing the pinion gear to better use
the bottom end acceleration, and get more top end speed with less rpm?
I just purchased one from HK to see just how much improvement I can get. But I wish
the long stroke engine was available at the US warehouse.
Bill M
wmazz is offline
Old 03-31-2014, 01:54 PM
  #199
wmazz's Avatar
Originally Posted by Roelof
Well.. within 1 brand having 3, 5 , 7 and 8 port engines the 3 port is made slower by timings and sold a cheaper engine.
One of the settings is a lower exhaust port automatically giving more bottom torque and a low top RPM.
Yes, more ports can give an advantage but in the basic an 3 port engine can be as fast as an 8 port engine.
And I wonder if the sleeve is 19.5mm in diameter, if so then for the 22 dollar
you can give old engines a new life....
Sleeve:
ID 16.5mm
OD 19.5mm
Crank pin bushing ID 4.95mm
Don't have a crank yet, so pin measurement will have to wait.
@ Roelof: With a 19.5mm diameter, will that cylinder fit in a Novarossi? if not
what engine were you thinking about.
Bill M.
wmazz is offline
Old 03-31-2014, 02:41 PM
  #200
R/C Tech Elite Member
hookem34's Avatar
Trader Rating: 17 (100%+)
Bill M
I did remove the copper shim on the stock engine and it yielded a slight increase in RPM, but it made the tuning window narrower and the engine ran a bit hotter. Not a huge issue for me, but not recommended for a novice.
The increased crank window timing and exhaust port timing made the biggest difference over stock. I think I am well over 6 gallons at this point and it still runs like a champ. Very little slop in the con-rod and the compression is still good; not great but serviceable. Will probably need a pinch in the near future and maybe a new rear bearing.
When I run it back to back with one of my CRE Werks B2's (also a 3 port; albeit heavily modified), it clearly lags in performance and looks like a $60 engine. But as I have said, it really is a perfect practice engine. Allows me to focus on my chassis setups on long practice days without burning up a quality engine.
I think I can make the AEG "on road" long stroke engine into a nice little club racer...
hookem34 is offline
Old 03-31-2014, 08:30 PM
  #201
rcboy1's Avatar
So this thing is still actually decent? I know I just became that guy who doesn't read the thread but I want to make sure.
rcboy1 is offline
Old 03-31-2014, 08:47 PM
  #202
wmazz's Avatar
If you don't mind, what glow plug and nitro percentage do you run.
Do you think it will run decent (for practice) on 10%?
Bill M.
wmazz is offline
Old 04-01-2014, 03:53 AM
  #203
hookem34's Avatar
Bill M.
Current plug is one of the new OD V2 plugs. Prior was a Werks #6. I run 30% Bones Brew with 8% oil.
10% oil should be fine in a 20 or 30% nitro fuel.
hookem34 is offline
Old 04-01-2014, 06:08 AM
  #204
Roelof's Avatar
Bill M.
Most Novarossi sleeves are also 19.5mm but I have heard some offroad models do use 19.2 as well. If the pistonpin is 4mm you can use a Novarossi rod. The only thing is to measure the depth of the ports but mostly that is no problem with maybe adding some shims.
Roelof is offline
Old 04-01-2014, 05:10 PM
  #205
wmazz's Avatar
The engine I just received from the US warehouse came with a completely
different cylinder, the crank has a labyrinth seal, and some pinch.
However, the block was not modified for the new cylinder.
I will post pics later.
wmazz is offline
Old 04-04-2014, 04:46 PM
  #206
22Racer's Avatar
Trader Rating: 67 (100%+)
Here is a pic of the ones I just recieved today. I ordered these with the 3 needle carb and coated crank.
Rex
22Racer is offline
Old 04-08-2014, 04:09 AM
  #207
easyryder's Avatar
Rex
Looks nice, like the idle adjustment better on it for sure.
Old 04-08-2014, 04:55 PM
  #208
22Racer's Avatar
A nice suprise, turbo cut crank, heavy duty rod!
22Racer is offline
Old 04-29-2014, 10:07 AM
  #209
Tiburon's Avatar
I'm going to buy one of these and win with it in my 6year old tamiya truggy with duratrax tires and laugh my nuts off.
Almost won last week but ran out of fuel in the 8 year old generic .27 with a minute to go
The driver is the most important factor in winning races.
Tiburon is offline
Old 08-22-2014, 06:58 AM
  #210
UrabusDenis's Avatar
Any reccomendations for a cheap pipe which works good with this engine?
Also, the motor 22Racer has on the pictures has a different carburettor to the one shown on the HK website. What do you get when you order?
UrabusDenis is offline
