Engine idle problems 2
Old 12-25-2012 | 07:40 PM
  #16
Suspended
and now that it's really cold out you probably need a hotter plug. I went out today and had to switch mine out to a hot one.
mtpocketsracing is offline
Old 12-25-2012 | 08:00 PM
  #17
jmackani's Avatar
Factory settings are normally way to rich. Set the idle like others said and use the HSN at first. If raw fuel is dumping out the pipe, keeping going in on the HSN until it's not spitting it out the pump so much. Do wot runs and listen for the top end to peak out. Once that is set, then adjust the LSN to get the rpm's to drop down after the wot run. Like others stated, if it's cold out you will probably need an ultra hot plug.
jmackani is offline
Old 12-26-2012 | 06:22 AM
  #18
So will the buggy dump fuel at idle if the HSN is more lean?
Sounds like I'm going back to factory.
zeBugMan is offline
Old 12-26-2012 | 06:08 PM
  #19
hustler777's Avatar
just out of curriosity, what kind of fuel are you using??? what's probly comming out of your pipe is oil, not raw fuel...
hustler777 is offline
Old 12-26-2012 | 08:38 PM
  #20
Byron Gen 2. It's 20% nitro and 16% lubricant.
zeBugMan is offline
Old 12-27-2012 | 11:55 AM
  #21
nitroexpress's Avatar
Are you sure that's what your using? I believe it's 12% total lube.
http://www.byronfuels.com/pages/products.html
nitroexpress is offline
Old 12-27-2012 | 06:56 PM
  #22
The bottle reads 20% and 16%..
zeBugMan is offline
Old 12-27-2012 | 07:33 PM
  #23
the race gen rtr is 20% and 16% oil if thats what he has
dooug1960 is offline
