ARO VS RUST
Old 07-13-2012, 09:08 PM
LosiPRRACER's Avatar
Default ARO VS RUST
So, i've just had a engine show some rust on its crank and rear bearing race,
the fuel i am using is byrons 25% 11%oil.
the engine i have has a silicone? insert in the crank and i think i may need to use ARO?
some guys here use Auto trans fluid, but am unsure if thats ok for the crank insert.
LosiPRRACER is offline
Old 07-13-2012, 10:01 PM
coneman's Avatar
i'd like to know this too
coneman is offline
Old 07-13-2012, 10:29 PM
houston's Avatar
Trader Rating: 96 (100%+)
Any petroleum distillate product is unsafe for silicone filled cranks , i would HIGHLY advise against it
I have said it over and over , when using byrons just dump fuel out of tank at end of day , DO NOT RUN ENGINE OUT OF FUEL/LUBRICATION!
This will leave a copious amount of byrons proprietary lube pkg in the engine , no rust will occur happy engine happy engine owner
A great oil to use for after run oil is castor ,nuff said
houston is offline
Old 07-14-2012, 06:52 AM
blktransam's Avatar
Trader Rating: 59 (100%+)
if you do need ARO I would recommend the ARO made by/for rcrenew good stuff!
blktransam is offline
Old 07-14-2012, 09:33 AM
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Try this product it been working for me and the others I referred. I'm on my first can its been well over an year almost going on two
http://www.amazon.com/CorrosionX-Lub...rds=corrosionx
bigjayjay1 is offline
Old 07-14-2012, 11:03 AM
houston's Avatar
once again castor oil
many ways to get it and its even available at your local pharmacy
i order byrons lube booster by the case , its the goods
houston is offline
Old 07-14-2012, 11:50 AM
Rcrenew's Avatar
Auto trans fluid is a great rust inihibitor. It is also highly detergent. It is not good though for Filled cranks. It will make it swell and come loose in time.
Rcrenew is offline
Old 07-14-2012, 06:43 PM
coneman's Avatar
i have a bottle of caster oil. so i'll use that.
coneman is offline
Old 07-14-2012, 06:53 PM
Trader Rating: 101 (100%+)
Default Storage
I have been using mineral oil from the drug store for long term storage and even after one of my engines sat for a year it was still like new inside. The only problem with it is it will ruin the glowplug if you don't run some fuel through the engine to flush it out before starting.
latemodel13 is offline
Old 07-14-2012, 09:51 PM
merdith6's Avatar
Default One thing
If you have had rust develop on the bearings and crank it would be a good idea to take it apart and clean it really well. I like to buff the crank with a wire dremel wheel, the carbon brush wheel works really good, and blast it really good with air and oil it with castor like Monty said. I tried it after he recommended it and it works really good. I also like the Nova assembly oil. Soak the bearings really good in the case with denatured and blast it, then put oil on them heavy, corrosion x works good too, and let it set for a day or two then go back and spin them and clean them again and reoil. If they are still ok it will spin smooth with no grittiness. Don't be afraid to remove the backplate and oil inside the engine heavier than you would think if you plan on not using it for a while.
merdith6 is offline
