Ten-T Pullstart?
Old 07-15-2012, 11:21 PM
rcking112's Avatar
Trader Rating: 26 (96%+)
Default Ten-T Pullstart?
Is there any other Pull Starts , Other then The LOSI one That comes with the 810?
I dont really wanna pay the 50 Bucks for the losi one... :|
Is there a cheaper one? That will work for the Losi 3.4 Engine?
rcking112 is offline
Old 07-16-2012, 10:57 AM
SolderGlob's Avatar
I think your only option would be the Losi one. If you're replacing the ross unit all you would only need the pull start assembly and the one-way bearing as the ross backplate would also work for the pull starter.
If you can get to a shop that stocks traxxas item, as most do, a pull starter and bearing from a TRX 3.3 might work. I don't see it being much cheaper than the Losi parts.
SolderGlob is offline
