mitch
Hey i just got the aluminum set from amain it was missing one black spring is that a needed spring to run all black. right now i belt it with two black and two yellow like the instruction say. Or if any one uses all black in a truggy if not then im not gonna worry about it.
spring choice for variable weight flywheel kit
Originally Posted by imrob
(Post 10480306)
This works really good on loose to medium surface tracks. |
Originally Posted by m2cracing
(Post 10488145)
Depending on the surface most of the guys like the (2) .9 and (2) .95
(Post 10490514)
i run a hard pack clay track with slight dust. I did try it out on the road and i got to say i love it was doing really good till the cop came after one tank of gas and said a person called and said it to loud. I cant wait to try it out at the track. what shoes work best for this type it a meduim track. Right now i have 12 grub screw in and the 2 .95 and 2 .1 spring in now.
this is in truggy. |
Originally Posted by jmaxey51
(Post 10490829)
i run 4 .95 ... all screws in aluminum, 8-16 screws in steel (just depends on how much traction, usually 12 or 16)
(Post 10490867)
ok i got the traction part but how do you know when the clutch is slipping by not hearing it. This would be helpfull so i can judge my springs and shoes needed for my truggy which is a hot body d8t. im used to a 3 shoe and i alway use to run what the manfurator had in the manual. so some info would be nice. cause i see some guy like hard shoes and some meduim i run a .28 motor with 3.4 claimed hp in this thing.
when i run the .23 in my truggy (mbx6t, which is a lot lighter) i use 4 .95, 16 screws, medium shoes, steel flywheel. run the same setup with buggy. the springs and screws, just play with and see what you like most. with screws, adjust 4 at a time and of course have them spaced evenly. |
clutch shoe adjustment
(Post 10490897)
i just dont like having different springs, i want all to hit at once. when i tried 2 .95 and 2 1.0, it had a gradual acceleration to me and slipping due to hitting at different times. some like some dont. i also always run medium shoes, hard sliped to much for me, but they do last longer though. soft grabbed harder to me, i like them on high bite. all the same concepts you use with 3 shoe will work with 4 shoe, you just have more tuning.
when i run the .23 in my truggy (mbx6t, which is a lot lighter) i use 4 .95, 16 screws, medium shoes, steel flywheel. run the same setup with buggy. the springs and screws, just play with and see what you like most. with screws, adjust 4 at a time and of course have them spaced evenly. try different setups and different weights. keeping down tire spin helps control the vehicle out of the corners and makes you faster and makes your tires last longer and you get better fuel milage. softer clutches seem to be what most guys want. |
Is the steel flywheel available yet?
(Post 10490897)
Originally Posted by nv529
(Post 10491871)
(Post 10492031)
ok thanks for the info so if i want it to rev more before take off i put in hard spring and if i want less rev soft spring. Sound good to me thanks for the info guys
(Post 10492267)
yes. also the weights play a roll in it also, more screws=more gradual acceleration (puts power to ground), less screws=revs quicker, more tire spin.
When do you guys change the shoes? I know someone mentioned they change before the dot. How far into the dot can I go before having to replace?
Just slightly- once they wear to the dot replace them
Thanks guess I'll be changing mine out.
| All times are GMT -7. It is currently 02:28 PM. |
