Go Engine USA 2011 Thread
#2656
LOL yeah it's getting a bit confusing. I did some testing/tuning today and 6 hours in from flush on the LSN just results in severe flooding. I'm at a point now where it idles well, responds extremely well to throttle input, has great smoke under power, maintains a temp of 210°-215° and only two stages for about 1-2 seconds after a WOT run down the straight. Pinch test results in 4-6 seconds of normal idle, a slight rise in RPM and then it dies.
FWIW I'm about 18 hours in on the LSN and 4-5 hours in on the HSN. Idle gap is exactly .7mm. The engine has great pinch and now that it's close to a good tune it is very powerful. I'm diggin' it!
#2659
they don't make the rod for them anymore so if you need to replace the rod in the future u will need to buy the new crankshaft as well, as the newer cranks have a larger pin for the rod. HTH
great avatar u have as well
#2660
new or second hand ?, if new it's a good choice for truggy with lots of bottom end power & enough top end to keep the smile on your dial.
Rex
#2661
Suspended
#2662
Rex
#2663
thanks for the infomation..
and thanks on the avatar...
im new to nitro,, ive been running electric for a while and just got a losi 8 t 2.0,, it has the losi 454 on it but the gas mileage is not there... im only getting about 6 min out of a tank.. and in a 20min main... im in the pit a lot...
what about tuning.. will it hold a tune pretty good???
#2664
Hey Bandit, if its the model before the GXI series (gold heads) it will be fine for a truggy, the 5 ports older than that had a few carb problems but the last of the silver head 5 ports had the alloy/composite carb.
Check the carb orings are ok before you run it, if they are the brown ones replace them with the black ones.
#2665
What you should do is measure the crank pin of a gen 5 and then a gen 5.5 or above and see for your self the gen 5 crank pin was 4.97 mm the new crank pin is 4.99. there no disputing an acurate digital measuring device.
The rtr go engine still have the 4.97 crank pin.
Hope this helps
Naa
Hope this helps
Naa
#2666
The new GX II PRS set will not work with older models. The cranc cases are different and so is the sleeve.
#2667
If you are looking for a new engine or parts we have them as well for older models.
http://www.ebay.com.au/sch/nitroaddi...&_trksid=p3686
#2668
1Likes
