Clockwork Racing Engines and Products...
#7246
Just like to give a big thanks to Neil and John at CRE. Ran my new CRE BTT all weekend with nothing but praise from me and my fellow racers. The motor pulled hard but smooth and screamed down the straight. This is after CRE's break in plus about 2 tanks only in the yard then off to the races it was. Barely even had to touch the needles either.
The only problem having CRE engines is deciding which one to run, my Clocked Mugen B 02 is also a screamer.
Don't hesitate, contact these guys.
#7247
Glad to hear Daniel, Hopefully you can make it out our way again this summer for some Fun in the Sun.
#7248
http://youtu.be/X5LcwSBJ5xo
http://youtu.be/_wtqqeyP0wk
Took a couple little video clips of my first run with the Clocked Picco Boost. I was running with my buddy in a agama truck with a novarossi bonito. Mugen Truggy orange and white
M2C clutch with 4-1.0's and 13t clutch bell and Nova 9886 pipe with 41029 header, so far the best combo from the werks 2058 and 9886 with short header 41001. Still 1st time out with it though.
Wheel to wheel action with ish taking in the mix. Love it!!!
#7250
If you pull the bearings out you can pretty much use about anything... I Have used hot tap water,bar of Irish Spring and a toothbrush...A few minutes of scrubbing, a blast of air and they come out clean as a whistle !!!!!!!!
#7251
#7252
Just take your time and thoroughly inspect the engine...look for scratches on the crank window , scratches on the piston, scuffs on the piston , heavy rubbing on the backplate.....If you see anything you suspect is not normal take some pictures and let me take a look at them
#7254
#7256
#7257
My clocked P5XLT ran amazingly well this past weekend. The Bones Brew 30/8 along with a P4 plug provided reliable performance and PLENTY of power. I have my Buku set up with no stagger and it provided great pop for the short run up jumps on the med/high bite indoor track. I was getting 12 minutes with a tiny sip left in the tank. When tearing down the engine it looked like a was running a touch lean. Going to fatten it up a bit for the next race.
My driving pretty much sucked but my gear was top notch!! LOL.
#7258
I am not 100% sure you were lean really...but based on your pictures the glowplug maybe looked a touch dry( need a better quality pic of plug coil )..... however the rest looked pristine......it just me that the fuel burns cleaner then we are used to
#7259
I have to mention that Neal remembered I had a race Saturday and he emailed me on Sunday evening to make sure that I was getting along well with the engine. That's just ridiculously great service!
