Pre Heating Engine
Old 09-29-2010 | 02:17 AM
  #61
Originally Posted by lambchops
There is also an alternative heater available which runs from a 11.1v lipo or 12v gell cell battery.
http:\\www.rcsurestart.com
My Deluxe model has thermal switching and two heat settings
I use the non deluxe version on my new Nitrotec 21 engine and it made running in an absolute breeze. Also it helps the amount of wear on the starter box motors and rubber wheel as it makes it so much easier to start. I also like the fact that at the start of my heat the engine is up to temperature which would normally have effected my first few laps of the heat. The engine still has a lot of pinch left which many of my engines in the past would have had a lot less left just after just over 1 gallon.
AmiSMB is offline
Old 09-30-2010 | 02:54 PM
  #62
I can't see how a competition heater would work at all! I mean your wrapping the head fin's .The piston and sleeve are in the engine block so tell me what's the sence in that?All your doing is heating the head button at best.Thats why a heat gun works best.
If some one came up with something that wrapped the block then that would be worth the money.Wrapping the head is stupit and there's nothing anyone can say about that.YOUR NOT HEATING YOUR PISTON AND SLEEVE!!!!!!!!!!!!!!!!!Think about it.
blacksunshine is offline
Old 09-30-2010 | 03:05 PM
  #63
This is got to be a joke! If its not thats gotta be the most stupid thing u could post!
theblackbart is offline
Old 09-30-2010 | 03:11 PM
  #64
Stubbs's Avatar
Yeah....
You ever hear of conductive heat transfer? The heat source is at the cooling head fins, but the heat is transferred throughout the entire engine. If left on for more than 15 - 20 minutes, you will actually get a good heat soak into the chassis.
Why don't you try one out before making a statement such as this, or just leave the reviews to those who have actually used them....
Stubbs is offline
Old 09-30-2010 | 03:19 PM
  #65
And that it why there is a fan in the top of the RC Sure Start heater which blows the air down over the crank case. The head is completely covered so as to retain as much heat as possible. I get my engine up to 90 degrees C after 5 mins from a 12v source and pulls under 5A. He really should have researched before he posted.
AmiSMB is offline
Old 09-30-2010 | 03:21 PM
  #66
sluggo_sx8's Avatar
Troll???
sluggo_sx8 is offline
Old 09-30-2010 | 03:25 PM
  #67
merdith6's Avatar
Default I use
I use a 20 year old hair dryer that works great. It's a small one that doesn't heat up other areas of the car, and works great on break in....
I kinda look at the heat products like the charger and radio wraps. Not really important....but to each his own.....I probably buy engines and tires with the same money spent on extra stuff that isn't needed for racing.....
merdith6 is offline
Old 09-30-2010 | 03:26 PM
  #68
Shane Racer's Avatar
The Competition heater is so easy to use even a cave man can do it
Shane Racer is offline
Old 09-30-2010 | 04:59 PM
  #69
helivaguy's Avatar
if your breaking in an engine at the field or away from home wrap the head in aluminum foil and carefully warm up head and block(at a distance)with a portable propane torch..go ahead and laugh..it works
helivaguy is offline
Old 09-30-2010 | 06:09 PM
  #70
Kalgard Racing's Avatar
Great for cooking the bearing grease, melting the O-rings in the engine also
Kalgard Racing is offline
Old 10-01-2010 | 12:46 PM
  #71
Would just like to say that
RC Sure-Start are pleased to announce there very own place of contact
http://www.rcsurestart.co.uk/forum/index.php
This is for ANY question's or queries regarding any RC Sure-Start Products plus alot more. Please pop in and say hi
jamiekerr14 is offline
Old 10-01-2010 | 03:02 PM
  #72
helivaguy's Avatar
sure..just as flamable and dangerous as the rebranded furniture polish products you sell your probably a engine heater device peddler also.
i knew i would get reamed..
only a mooron would hold it directly at the head and block..
obviously you keep the torch at a safe distance only for a few seconds at a time.
cant someone share there own method of breaking in a engine away from home without someone trying to sell them something or needing a whole arsonal of trackside equipment to do it??
Old 10-01-2010 | 03:11 PM
  #73
man you guys are all going weird a heat gun is only like 8-15 dollars and weorks great for the price
the engine warmers are cool if yhou have time but i just heat gun the thing for 2-3 mins and ready to fire up but all being said if i had money laying around i guess it wuold be cool to have engine warming while i was doing something else. like bench racing in the pits that is always fun
jewn_beef is offline
Old 10-01-2010 | 03:47 PM
  #74
wow you guy's are really sold on the heat wrap dealy eally o.I guess you put your temp gun on the head and say wow this thing works gteat.To each there own.I guess i don't want to be sitting around the pit's spraying kalgard all over my body and having my head warmer on my truggy thinking how cool i must look
Old 10-01-2010 | 03:54 PM
  #75
Jewn_Beef- You say-"If you have time".. all you do is pop it on.. and then leave it until your ready to go.. heat gun=Need a wall socket.. or a generator ect..plus then you have to stand around for the 3 mins moving it around the engine.. while the other guy. Is chatting, or checking screws.. while you have less time as you have to stand around moving the heat gun around.. and hoping to get a good enough coverage.. it heats up the whole case.. not just 1 spot..
blacksunshine-If you dont want to prolong your engine life.. and save on some some £ long term then go ahead.. No one is making you get one, but in the long run they make sense.. Enjoying slamming you cold piston up against you liner and lessoning the pinch each cycle.....
