REDS Engines (Mario Rossi)
#1426
I have a REDS R7, and it comes with the 7.0 venturi as well as an optional 6.5. I have been getting poor fuel mileage (barely 7 min and bone dry after that). I am going to change to a REDS 2014 pipe with the XS manifold, go to the REDS Quattro clutch, and change the venturi to the 6.5. I'm pretty sure this will help fuel economy. Is it reccomended to not go any lower than the 6.5 venturi? If i were to go lower this would kill my power, correct? Are my thoughts on the right track? Thanks for the help!
#1427
BTW 7 minutes is too little in my opinion (unless it's a really fast track)- is the carb tuned right?
#1429
#1430
Thommi and UrabusDenis,
All good points, I didn't think about only having a a gallon or so through the motor. The carb should be tuned right, I actually had a REDS team guy help me tune it. Throttle control is probably a biggie along with the new clutch. Thank you for the responses, I guess I was looking for a general confirmation, too... Awesome!
#1432
New engine for the USA FYI, if you haven't seen the facebook post:
REDS Racing introduces new R5S US Special Edition
REDS Racing introduces a new 5-port engine called the R5S Special Edition. It is specifically designed and built for the US market. From the HCX carb to the precision crankshaft, this engine will excel on US style tracks with a wider power band and solid runtimes. The engine’s quality, performance and a MAP price of $299 is completely unmatched. The R5S Special Edition fits nicely within the current offerings of R5R 2.0, R5T Team Edition 3.0 and the R7 Evoke 2.0. Come celebrate your buggy and truggy independence with a R5S!
For further information and ordering, visit:
http://www.reds-racing-usa.com/R5S
#1435
that's a difficult one to tell, it all depends on how accurate your LSN was when you started moving your HSN. If your idle gap is good, then you just adjust the LSN so that the idle gain is stable. if the idle gap is off, you will have to work both LSN and idle screw. You can do a rough temp test on your LSN. Rev the engine and let it fall back into idle, then temp it continously. Temp should not go higher (this would mean a lean LSN) and not drop too much (whould mean rich LSN).
#1436
Free shipping at BeachRC on the new Reds engines (technically anything over $125
http://beachrc.com/reds-racing-usa-r...ceted_search=0
#1437
yeah im useing this set up now.. loving it... smooth controllable power and idles like a dream.. temp around 97c is ideal.. as mentioned in the past by others.. the clutch in L as suggested is good good for loose to medium traction tracks.. as is on our track here.. even when i throttled the car and had it rooster tailing.. keeping it steady wasnt overly challenging.. the wear from just after breakin has been fairly good, just keep it clean in the clutch bell, which im sure you know..
happy driving!
happy driving!
I got the r7 week before race and there was time to run just over a gallon with the engine. I was able to get barely over 7min with 6.5mm venturi. It was 45min final and it was too risky to go for 7.30 strategy so I had to go for one extra pitstop with cost me good battle for 5th place. Ended up to 7th.
What mileage you guys have with the engine and do you think that I just need to drive more with the engine? Theres still fairly strong pinch
I'm not allowed to post links so if you want to see the track, put in youtube "M8 SM 1 2015 | A-Main Final 45min". In 4.15 mark I'm driving with the red car. Rear end taked off and caused the crash lap after
#1439
The combo has been excellent. Easy to tune for amateur and very smooth power and all the topspeed I'll need. Clutch works great with mugen and I have been running in "H" mode. In my first nats I was able to get to the a-main but the track was polished and really slippery by the mains so it would been nice to try the "L" mode. Going to do some more testing. The reds clucth bearings feels nice too, just as good as mugens own.
#1440
