REDS Engines (Mario Rossi)
#1411
Hey, have R5R, have about 17 liters on it, still
Runs good without problems, wondering when should I change front bearing, piston and sleeve, so I wouldn't be late and didn't ruin engine, what is mileage for piston sleeve change, when how to indicate that it should be done?
Another questiln, when change them, should I break in with old conrod and add new one after break in is done? I had one guu here whos conrod failed after 4 liters and red that here also some had problems with it...
#1412
during the break in process, you are putting a big strain on the rod as a) the engine still has mechanical pinch and b) you are running a rich engine. The forces on the rod are much higher than with an already ran in engine and I would NOT use an old rod for this process. I never had a rod going bad on me after breaking in a REDS engine, but do change them on a regular basis around the 4 or 5 gallon mark, just to be on the safe side. There are other brands having a much higher mechanical pinch in the beginnin where I suggest changing the rod after the break-in process, but I have never felt the need to do that on the REDS engines.
#1414
Does anyone know of some alternative cooling heads which fit the Reds R5R engine? The original one on my engine broke and unfortunately the Alpha head which I have doesn't fit, neither with its head button. Or if anyone has a cooling head from an old Reds engine they'd sell?
#1415
#1416
I'm getting R7 with S manifold and 2104 pipe. I'm also intrested getting quattro clucth. Have you guys used the basic 2x carbon 2x aluminium shoes and L "mode"?
#1417
High rpms in mid air?
The motor runs great. Smooth and quick. Idles clean when I pull it off but off the bigger jumps it revs high when I let off the throttle. I figured the bottom was too lean so I fattened up 2 hours but still does is. Fattened up the top 1 hour and same deal. Any ideas? Thanks
#1418
#1419
Sounds more to me like the carb is not closing properly in neutral. You use a return spring or elastic band?
#1420
happy driving!
#1422
Idle gap to big or High needle to lean if carb is closing all the way of throttle. You said to run the band. Check the linkage also to make sure its closing all the way.
#1423
+1. Hsn too lean. Idle gap too big or collar on carb linkage hitting servo horn which is preventing carb from closing.
#1425
don't read too much into temperature. there are diferent ways on how you can end up with 200F, and it doesn't have to be the correct one. Focus on getting the engine to work, and with that, temperature will be right. The REDS engines are good when a bit rich on the LSN. Keep idle high as it usually drops when heating up. But agree with the others, linkage has to be fine, everything has to be completely closed. What venturi are you using? If you are not that experienced with the REDS engines, start with the 7mm venturi. The tuning window is wider and you will struggle less.
