REDS Engines (Mario Rossi)
#1381
Thanks everyone guys. All seems reasonable to get one.
#1382
My engine would flame if I pulled the throttle abruptly, it would bobble, spit and gurgle and then being to lean out of I pulled the trigger slowly.
When I would get the throttle to clear out and let it go the idle would come down slow and steady. As I leaned out the bottom the it went from a gradual decline to a definite 2 stage, high idle and drop. As I leaned further and richened the top the high idle stage reduced and eventually went to zero.
When setting the idle to I measure with the Venturi on or off?
And btw, thanks to everyone I'm learning a lot through this process.
Measure the idle gap with the venturi out.
#1383
great info thinking of picking up the evoke 7 in the future .. hard choice..
#1384
(R5R) The manual recommends changing rods after break-in, but I didn't, basically curious about lifespan, I probably will when I run the more expensive R7.
So far I have 25 Litres on it and zero problems with running. The crank has a little wear of about 0.04mm on the clutch bearing end, so I am monitoring that, but it doesn't seem to be causing any problems.
#1385
some breaking with 2min run then stop , let it cool , run for 2 min , then same thing.. and after 5 it should be ok to race tune.. thats with OS engines.. and this coming from a experienced tuner..
#1386
I have my reds r5r broke in and I'm doing some fine running on the engine, this is my first quality motor as I've only had bashers in the best and if theres one thing the traxxas 3.3 taught me its how to tune lol .. This thing was so easy to tune in comparison, I'm running 30% nitro and its running between 215-225 after multiple wide open passes with the body on the buggy, is this the ideal temperature range because it feels to me that its absolutely screaming and I'm afraid to go any farther. I took a temperature right at the end of a tank as it was leaning out and it got to 240 which I'm ok with if thats with operating temperature.
#1387
#1388
had run the buggy with my reds quattro clutch and maan
the delivery of power is so goooood.. i have it on soft spring set up for loose track .. even my mate who runs the 2015 ed 998 said its really nice and plush and yeah power is enjoyable.. when you want power you get it... its just so good
#1389
alright ladies and gentlemen, my engine saga continues.
I raced both my buggy (with the r7) and my truggy (with the R5TE 3.0). Once again at the start of the day I took both engines back to flush and tried to get them to run without severly leaning out the bottom.
I even recieved help from a Picco team mechanic who's driver went on to win the Pro Buggy.
The r7 in the buggy was tricky for us to tune and it took the first two rounds of qualifying to get it right. It would be real slow to get up and go, but would tend to run on at the end of the straight. What made it so hard was it would sound great on the box but run like crap. We finally ended up with a tune that sounded horrible on the box. I could see other people on pit lane looking at it with that WTF look as it sat warming up, but it ran like a champ.
Here is where my settings were at:
The truggy was much of the same story. We tried to lean out the bottom, but we went far that idle screw no longer was able to bring down the idle to a reasonable level and still felt like it needed to be leaner on the bottom. The main was a horror show. The truggy would barely accelarate from a stop. I literally came in after every lap to get it leaned until I had just enough power to clear most of the jumps.
It is also worth noting that both motors have very little mechanical pinch after 2.5 gal through each of them.
#1390
Attachment 1291033
Attachment 1291034
Attachment 1291035
Attachment 1291033
Attachment 1291034
Attachment 1291035
#1391
Thoose needles i way off what i would say is normal.
What glowplugs du you run? could you take a pic of the plug and show me?
What fuel do you run?
#1392
Got a question for the people that have ran or are running the Reds Quattro clutch setup. Do factory clutch bells work on that clutch setup or do you have to run Reds clutchbells? Really just wondering about the Kyosho MP9 setup using factory Kyosho 13t lightweight clutch bells.
#1393
just obv sit it firmly :P
#1394
Good to hear, glad you liked it.
#1395
Attachment 1291033
Attachment 1291034
Attachment 1291035
Attachment 1291033
Attachment 1291034
Attachment 1291035
