REDS Engines (Mario Rossi)
#2701
In this case it is only the rotating backplate with (I think) small 10x5 bearings, not much to gain compared with the whole rotating mass the engine must power (own crankshaft up to the wheels).
#2702
Dang it I bought one to go on my new Gen 4!! So, you guys got experience with this backplate? bearings not holding up? no oil to the bearings? No real overall improvements anywhere?
#2703
Rotary Backplate
#2704
Hmmmm, Well add it to my pile of rc stuff I probably won't ever use!! LOL!
#2705
RTX
You seem to have misunderstood something, there is nothing wrong with the RTX rear plate.
It is clear that this part cannot create a "day and night. difference. The purpose of the part is clearly to reduce friction in the crankcase.
My objection is that it adds additional moving parts to the system and therefore more maintenance is recommended.
Most riders around me neglect their engines, which is a major reason for poorly performing engines and disappointing weekends.
And that is the reason why I have issued a warning here.
The ball bearings are designed to be as small as possible for understandable reasons. The same size as the clutch.
There is little oil on the bearings and not "no oil"
Canas won the Euros last year with the RTX.
It is unlikely that he will go into a 1 hour final with an untrustworthy part.
Happy motoring👋🏻
#2706
Happy motoring👋🏻
Happy motoring👋🏻
#2707
This is a practice that is as old as the combustion engine itself.
#2708
Commercial it is just better to say the teamdrivers have the same engines.
#2709
"Untrustworty part?"
Happy motoring👋🏻
Happy motoring👋🏻
are not as meticulous with maintenance...this is where the viability of the backplate comes into question...I have many, many, many hours on my backplate and have no backplate bearing concerns. Why? Because there is none! I think we have to evaluate where we are in rc as individuals...weekend warrior type...plenty of time to tinker type...chasing national championship type? That'll determine what level of "performance" and maintenace one should choose in my opinion.
#2710
Again it’s nothing wrong with the RTX
It is not rocket science .
Just look after it from time to time and you will be fine.
#2711
#2712
Well that is god news! Having a stable idle is important to me! That will more than pay for itself.
I'll service those bearing when I service the clutch, no big deal , 4 backplate screws.
I thinkI can handle that!!
#2713
The new 721 SCUDERIA GEN4 PRO SUPERVELOCE can be purchased with either the RTX backplate or the air boost backplate.
https://www.reds-racing-usa.com/shop/721-SCUDERIA-GEN4-PRO-SUPERVELOCE-SV-WITH-RTX-BACKPLATE-p623559273
https://www.reds-racing-usa.com/shop/721-SCUDERIA-GEN4-PRO-SUPERVELOCE-SV-WITH-AIRBOOST-BACKPLATE-p623565276
#2714
Could there be a New Reds 521 Sport in 2024?
#2715
Gen 1 and 2 721/723 carb issues
Just thought I’d toss this rod but if info in here if anyone is interested and is still dealing with the reds 2 needle carb and can’t get tuning down. I have the green head sv and the red head 723 both with the problematic carb. I have tried everything from colder plugs to head shimming changes(adding shims) and have never been able to get a stable idle. I had a new performa 7 port and a bunch of nova carbs and decided to try both. The performa immediately changed everything about this engine and the nova carb as well. Stock head shimming,30% vp tessmann blend and a p3/t3 plug. I’ve had these engines for years and they’ve just sat while I’ve run mostly os speeds, novas and finally can get some use out of these engines. They run flawlessly with immediate drop to idle and super easy to tune now. Maybe one day I’ll get the new 3 needle carb and give it a shot. I dunno.
