Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
TecnoPower Engine Thread ( From Rody Roem ) >
Old 01-21-2011 | 11:04 AM
  #406
Tony Newland's Avatar
Bearings are good as any... we get 8-11mins in buggy and slightly more in truggy.
Tony Newland is offline
Old 01-21-2011 | 01:50 PM
  #407
Where can I get the .23 truggy engine, contacted amain and they said they don't plan on carrying it !!
travertini is offline
Old 01-21-2011 | 01:56 PM
  #408
motomatt's Avatar
nitro-north.com
motomatt is offline
Old 01-21-2011 | 02:56 PM
  #409
wingracer's Avatar
Originally Posted by Ultraspeed84
I didnt mean for it to come off like that lol.. But ive had a lot of RB motors as of late with bearing failures...
Which as of late, has nothing at all to do with Rody or Technopower.
wingracer is offline
Old 01-21-2011 | 09:54 PM
  #410
If anyone needs some of the H6 or H7 plugs let me know, I've been sitting on a ton of them for a long time and would like to move them. PM for details
Old 01-27-2011 | 01:14 PM
  #411
aznitronut's Avatar
Where can I buy the 2069 pipe?
aznitronut is offline
Old 01-27-2011 | 02:01 PM
  #412
any info on the .23??...
What pipe combo...run times..etc..
neophyte6 is offline
Old 01-27-2011 | 05:36 PM
  #413
http://www.amainhobbies.com/index.ph...filter_mfr/731
There's quite a few .23s out there, I personally havent ran one. No truggy in the arsenal currently. Maybe some of those guys will chime in
Old 01-27-2011 | 05:43 PM
  #414
J.Whiting's Avatar
Super Moderator
From: a very small town in wisconsin that is in the middle of absolutely no where
the .23 is perfect for a truggy.. bottom end of the c-6 ( but has more ) and the rpm's of any .21.... best of both worlds.. ran a 6.5 restrictor last weekend.. could have gone to a 6mm with out loosing power.. the .23 has plenty to spare.. smooth but yet strong power band.. think of it as a modded c-6 with extra power to spare... very very nice motor.. jeremy
J.Whiting is offline
Old 01-27-2011 | 07:15 PM
  #415
aznitronut's Avatar
Thanks on the pipes info, what difference does it make with the different headers? I bought a new engine with pipe included, new, from one of the guys that had posted n this thread, the pipe is the 2069 with the 192 header, how does that work with this engine? The 2034 looks like a 2053 pipe.
Old 01-27-2011 | 07:22 PM
  #416
aznitronut's Avatar
Has anyone tried using the 198 header with these pipes?
Old 01-27-2011 | 08:40 PM
  #417
motomatt's Avatar
The 2069 "Strada" pipe shown at A Main displays an on-road manifold.
http://www.amainhobbies.com/advanced...hipex&x=7&y=14
The 2069 and 2034 available to me from Racer Dist. both come with the 192 off-road manifold.
I would speculate that the "Strada" would be used with the R-01 Rally Engine in 1/8 on-road applications.
2069 off-road (bottom end)
2034 off-road (mid-range)
This is from a FAQ at the TecnoPower website:
"TECNOPWER is suggesting to use the HIPEX pipes and manifolds which we supply with our engines, the following pipes we have available are:
* EFRA 2069 This pipe we have found very smooth with a good bottom-end power, this in combination with the HIPEX speed manifold you obtain very good results with our engine.
* EFRA 2034 This pipe we have found very smooth with a good mid-range power, this in combination with the HIPEX speed manifold you obtain very good results with our engine.
Other pipes which are working well on our TECNOPOWER engines are:
* FEMCA 0801 According our distributor RC PRO in Australia this pipe also seems to work quite well with our engines."
I hope you find this helpful.
Moto
motomatt is offline
Old 01-27-2011 | 10:09 PM
  #418
aznitronut's Avatar
Thanks, the strada pipe does look to be an on-road pipe, still curious of how 198 header would perform compared to the 192 header. I know the longer the header, the more bottom end.
Old 01-28-2011 | 07:04 PM
  #419
It is an onroad header.. but thats all thats out there. You might check with Ascendancy they are the newest re-bag of the stock engine and might be bringing in the pipes
Old 01-28-2011 | 07:13 PM
  #420
J.Whiting's Avatar
Super Moderator
yes more bottom end.. i use the 198 when there is alot of jumps just off corners.. you loose a tick of top end but if you dont have a 150 ft straightaway or more you will be good to go
