Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-28-2019 | 07:22 PM
  #10306
Originally Posted by J.Whiting
Off-Road Nitro Engines - NOVA - NOVAROSSI WORLD
click on the link. scroll down and find your motor. click on it.. on the right side of the new screen there will be an "exploded view" click on it and all parts will be listed.
but looks like these parts are needed for pull start to work
22812
13017
22803
plus the screws and oring
thanks but I already looked at the exploded view. And I'm trying to gather parts for a pull start to roto start conversion, I don't need more pull starter parts. No where in those truggy 28-8 pictures does it mention the starter shaft/rod, the piece that goes from the starter to the roto start backplate.
InTheZoneAC is offline
Old 05-28-2019 | 07:33 PM
  #10307
J.Whiting's Avatar
Super Moderator
From: a very small town in wisconsin that is in the middle of absolutely no where
gotcha.. check the 28-8 rt motor then.. thats the roto start version of your pull start engine..
J.Whiting is offline
Old 05-30-2019 | 12:17 AM
  #10308
Chad Millikan's Avatar
Here is the part that goes into a drill to rotate the engine. I suppose you could use an old driveshaft too, as long as the pin is 1.5mm or less.
Chad Millikan is offline
Old 05-30-2019 | 12:19 AM
  #10309
Also here is the exploded if the RT
Old 05-30-2019 | 05:34 AM
  #10310
Thanks. That's what I ordered since I saw it listed for an older 28-7 motor, and just assumed they wouldn't change anything. Since I'm unfamiliar with roto starters does that part fit into a drill or a starter, or is it specifically just for a drill? Thanks again.
Old 05-30-2019 | 08:16 AM
  #10311
It is a 1/4" hex. Just make sure it turns counter clockwise. One thing that I really like about the Novarossi rotostart, is that you can adjust the orientation you need it. You can adjust it anywhere 360°
Old 06-21-2019 | 01:56 PM
  #10312
petersen114's Avatar
Any opinions on the Rolling for truggy?
petersen114 is offline
Old 06-21-2019 | 02:18 PM
  #10313
J.Whiting's Avatar
Super Moderator
I have run it in mine with no concerns. 9901 pipe. 41021 header.. I use 2x1.1 springs and 1x1.10 spring for my clutch. 3 shoe..
petersen114 likes this.
Old 06-21-2019 | 02:24 PM
  #10314
I have a 51020 pipe and a 42021 header on hand. Using the Nova buggy clutch.
Old 06-21-2019 | 02:32 PM
  #10315
J.Whiting's Avatar
Super Moderator
give it a whirl.. I just found it need tick more clutch stall for a tick motor bottom end on my eyes but everyone drives differently.. maybe the pipe will give you the tick more bottom. but its a good motor overall.
Old 06-21-2019 | 03:38 PM
  #10316
I do have a 9901, but it’s in my buggy. Guess I could also go wi 4x aluminum shoes? Not sure what springs I would have to go with though.
Old 06-21-2019 | 06:14 PM
  #10317
J.Whiting's Avatar
Super Moderator
if a 4 shoe I would probably change the 2 lightest springs for 1 step up from your heaviest springs you currently run..
your normal clutch set up.. hypothetical clutch setup
2x1.0
2x.95
I would change to
2x1.0
2x1.05 or 1.1 springs
and go from there.. hope that makes sense
Old 06-22-2019 | 06:08 AM
  #10318
[QUOTE=J.Whiting;15468796]if a 4 shoe I would probably change the 2 lightest springs for 1 step up from your heaviest springs you currently run..
2x1.0
2x.95
I would change to
2x1.0
and go from there.. hope that makes sense[/QUOTE should I go with the 4 aluminum with this spring change or keep the 2 carbon 2 aluminum that I am currently using.
Old 06-22-2019 | 08:11 AM
  #10319
HaulinBass's Avatar
41001 with a 9901 7mm restrictor 3x 1.0 with soft aluminum shoes is stupid fast with tons of midrange power. The motor has more stock crank timing than any other motor I've taken apart she's a cheap beast.
dont use a 4 shoe in truggy not enough clutch shoe area
HaulinBass is offline
Old 06-22-2019 | 02:23 PM
  #10320
srt4johnny's Avatar
In looking hard at the Nova Elite 5OFF .21 hard to pass up for the price. Looking to run this in my 8ight T 2.0 truggy what pipe/header would you guys recommend. Losi clutching ok or should I look into Novas?: thanks
srt4johnny is offline
