Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-06-2015 | 06:29 AM
  #8071
Suspended
Originally Posted by sn47som1
How come the Elite engines are so well priced? I keep hearing and seeing great things about them, is it really because they are made with old stock?
I tried the Elite 5, and didn't like it compared to my Keep-off 4S. It had no top end, and I barely made it through break in before selling it. If I order another motor it'd be the Rex Legend 4 - It's a Keep off for $100+ less.
Socket is offline
Old 08-06-2015 | 06:51 AM
  #8072
The elite 5 is the P5 XLS, It not as good as the Keep off 4S, The Legends 4 is the Keep off 4S.
wichitafc98 is offline
Old 08-06-2015 | 07:34 AM
  #8073
Maximo's Avatar
what pipe/header and carb insert ?
Maximo is offline
Old 08-06-2015 | 09:04 AM
  #8074
Novarossi Offroad Exhaust Set 9901 EFRA + 41021 Manifold. I believe.
Old 08-06-2015 | 10:15 AM
  #8075
Maximo's Avatar
The 4 port has no more top end then the Elite 5........ If you guys are all using the blue 6.5 insert in the carb all the engines are going to struggle on the top end... 9901/41021 is also going to take away some top end as well......... in the end its going to come back to setup..a Elite 5 on a 6.5 mm insert 9901/21021 isn't going to have much top end, however changeover to a 8 mm insert and a 9853/41001 combo and the engine is going to scream comparatively.... The fastest way to kill the top end is to run a small carb insert !
Maximo is offline
Old 08-06-2015 | 02:22 PM
  #8076
Suspended
Ran a 7.0 insert and 41021/2096 on the Elite 5. On the Keep-off 4 I'm running a 6.5 insert and a Losi RE12 (9901 clone). Going to try the 41021/2096 on it this weekend and a 7.0 on the Keep-off.
Socket is offline
Old 08-06-2015 | 02:23 PM
  #8077
bash bros's Avatar
+1
Haven't ran my Elite 5 yet, but I've got a p5 and x5 and the 2096/41021 combo with a 7mm venturi completely smothered the life out of both of those engines.
Went back to the 053 w/ 8mm venturi and it's a night and day difference. Even the 7.5mm insert doesn't seem to sacrifice much top end... jury's still out on the run time vs. the 8mm though.
bash bros is offline
Old 08-06-2015 | 05:20 PM
  #8078
sn47som1's Avatar
My favorite insert is a 7.5mm. Its got great bottom mid top and a little better mileage than an 8mm. 8mm most situations decreases your traction because of the sheer power output/wheel spin, it's too much of a handful. If you like to drive the car run a 7.5, if you like the car to drive you run an 8. On anything but super high traction 7.5 is the greatest of all worlds.
sn47som1 is offline
Old 08-06-2015 | 05:22 PM
  #8079
kgombe's Avatar
i feel the same about the 7mm... :-)
kgombe is offline
Old 08-06-2015 | 06:11 PM
  #8080
I run a pre-ss 9886 and Long square Nova Header on a Crono RS5 (P5). How would it change with a 2096/41021 or 9853/41001?
Chris Reilly is offline
Old 08-06-2015 | 08:18 PM
  #8081
bash bros's Avatar
Buggy or truck?
Didn't care for 2096 in my mbx7t. But a lot of people like it for buggy, its pretty smooth from top to bottom and gets decent mileage. Probably best on a low bite track.
9853/41001 is my favorite for the p5 so far. It's known for it's low end and mid range grunt, but even with a p5 in my truggy it doesn't lack any top end at all. Kept up with all the fast guys the other week on the straights no problem... its the turns that get me
Old 08-06-2015 | 08:23 PM
  #8082
RC8B3 Buggy
Old 08-07-2015 | 06:46 AM
  #8083
Default Mito, Legend, Elite
Does anyone know what the differences are between these 3 products.
What is everyone using and why?
I need to get an engine for my Mugen Mbx7r
Italo2275 is offline
Old 08-07-2015 | 07:02 AM
  #8084
Suspended
Which Mito?
Which Legend?
Which Elite?
Socket is offline
Old 08-07-2015 | 05:23 PM
  #8085
cczjordan's Avatar
Same novarossi products
Rex n top is modified a bit, that all
cczjordan is offline
